| Write-Up: Fuel Door Hinge Pin Repair | |
+9LARRY70GS albertj 96RIVMANN gmann3001 Karma 1998 Riv deekster_caddy ibmoses cjoform 13 posters |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Wed Jun 06, 2012 4:11 pm | |
| Morad has nothing, going to try to check local yards. | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8622 Merit : 180
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Wed Jun 06, 2012 7:27 pm | |
| - 1998 Riv wrote:
- Ok, door is off. I've soaked the hinge pin with PB blaster for a few hours. This sucker is really rusted in. I do not believe it will drive out, from either the door or the bracket. Time to search for a replacement.
Can't drive it out, have to press it out or drill it out. I am thinking car-=part.com would have one available -- anyone with a Riv on the lot would be fair game even if they don't list the filler door. For the rest of you - if yours is not rusted yet spray it with lithium garage door lube or some such. Albertj | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Wed Jun 06, 2012 9:28 pm | |
| - 1998 Riv wrote:
- Morad has nothing, going to try to check local yards.
Dave, Go on V8 and PM George Nenadovich (GStage1). He has gotten me Riv parts. He's in the yards all the time. Give him a shout, he can help. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Wed Jun 06, 2012 9:54 pm | |
| Found one from an ebay seller pending pics. Already posted on V8. Will check local yards when i get a chance. Drilling it out... didn't work well. Can't press it out here. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Thu Jun 07, 2012 7:50 am | |
| Ok, who can tell me if the 95-97 and the 98/99 door will interchange? They have 2 different part numbers. My first guess might be how they are mounted? I may be able to get a white 96 door, but need to know if it can be used on my 98. Anyone??? | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Fri Jun 08, 2012 8:47 am | |
| Dave, Just heard from George. He said he has one for you, and is getting another today. George is the best! _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Fri Jun 08, 2012 8:54 am | |
| Yep, he's hoping for a dry day today to go see the white car. I am still concerned about the differences in the model years. It appears the early ones have a bracket built into the back side of the door, to hang the gas cap on. Mine simply has a notch on the side to hang the strap onto. I likely will need to remove that early model bracket for my use. After I replaced my filler pipe a couple years ago, the gas cap now sits right up almost against the back of the door, leaving little to no space for that gas cap bracket. I'll just have to figure out the best way to cut it out. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Thu Jun 21, 2012 5:18 pm | |
| Got a nice white 96 door from George, and with some mods it works fine. Not diamond white, but white is next best thing...
Had to cut off, then grind down, the brackets on the backside. They interfered with closing the door as the new fill pipe and cap are higher up and out than the oem. Also had to cut out a section of metal in the lower section of the backside for clearance. But hey for $20, it looks a heck of a lot better than no fuel door. | |
| Subject: Write-Up: Fuel Door Hinge Pin Repair Mon Aug 13, 2012 6:55 pm | |
| I had the same thing happen to me last week. My car is almost 15 years old, and had 248k miles when the hinge pin failed. Based on typical MPG, and average miles between fill-ups, the car has been fueled an estimated 650-800 times in its life. I was about to pump gas and the fuel door wouldn't open, so had to pry it up with a soft piece of plastic, then it popped. The pin had rusted through at two points: On the mounting bracket there are two tabs, one at each end. Bend these out straight. I used a bench vise to hold the bracket. Don't worry much about the paint - it's going to chip away: Clamping the bracket in the vice, support it so the pins can be driven out. I used a piece of scrap steel. Lube with PB Blaster for a few minutes. To drive out the pins, use a drift or whatever you can find (small driver bit works): Done: For the fuel door, you'll need to cut out the center portion of the hinge pin. I used a Dremel cut-off wheel: Drive out the pins: Done. Now I need to clean and protect the hinge parts from corrosion, then repaint them. I will probably use rust converter in a spray can, then paint with a quick dry enamel. I don't really care about matching the color, so it will be probably be black. For the hinge pin replacement, I picked up a 1/8" brass rod (3" long), from which I will use just a couple inches. If anyone else is performing this repair, let me know and I'll send you a piece. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Mon Aug 13, 2012 7:46 pm | |
| A brass rod. Cool beans... this won't happen to you twice. And thanks for the writeup!
ALbertj
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Tue Aug 14, 2012 11:47 am | |
| Aaron, I haven't given up on fixing my original door just yet. But I need to get back at soaking the pins with PB blaster again. They wouldn't budge after a couple days. I may need to actually submerge them in it for a while.
I'd like to take you up on the offer of some of that brass rod if you still have? | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Tue Aug 14, 2012 1:55 pm | |
| Yes, I'll cut a piece to length and send to you tomorrow.
If its really stuck, Use a 1/8" bit to drill out the pin. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Tue Aug 14, 2012 3:31 pm | |
| Tried 2 drill bits before, wouldn't bite. May need to pick up new(sharp). No hurry on the rod, whenever it's convenient for you. Thanks! | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Tue Aug 14, 2012 3:41 pm | |
| I had one pin that was being stubborn, so had to get out my trusty Makita cordless: I used a new DeWalt 1/8" bit. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
wvman2374 Special
Name : Anthony Age : 50 Location : Morgantown, WV Joined : 2012-10-27 Post Count : 5 Merit : 0
| Subject: Replacement Fuel Door for 99 Riviera Thu Jan 09, 2014 1:28 pm | |
| The fuel door for my 99 Riviera is gone. The pin had rusted through some time ago, and while refueling on the highway I had laid it on top of the car and forgot about it, driving off, and not realizing till a good 100 miles later. Ooops!
Does anyone know where to find a replacement? Or even an aftermarket type replacement? I've seen cars with chrome type fuel doors that look like aftermarket additions, but can't seem to find any that suggest they would fit the Riv. Any help in finding something suitable would be greatly appreciated. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Thu Jan 09, 2014 1:38 pm | |
| Good luck. Body parts for the Riv are far and few between anymore. Your best bet is to find one at junkyard somewhere. You can try calling the dealer and see if they can locate or get one for you. As far as I know, not one single aftermarket door is available. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Thu Jan 09, 2014 1:57 pm | |
| E Mail George Nenadovich at GStage1@BuickPerformanceClub.com George is one of my fellow Buick clubmembers, and he makes a lot of junkyard runs in Florida. He has gotten me plenty of parts for my 98. I'm sure he could help you. There was a 98 Riviera some time ago that I posted a thread about. George got me and some Riv board members parts. He is a stand up guy. Give him a shot. https://rivperformance.editboard.com/t10193-1998-riviera-for-parts _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Thu Jan 09, 2014 2:40 pm | |
| No pro bro.....eBay's full of parts. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Thu Jan 09, 2014 4:17 pm | |
| Also try car-part.com and http://www.moradpartscompany.com - Morad's specializes in 3800 cars and they occasionally bring a Riv through and part it out. I had to replace mine a few years ago and bought one through the dealer. It was surprisingly not very expensive. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair Tue Oct 10, 2017 12:40 pm | |
| While we're waiting for the "new posts" fix, I'm posting a comment about repairing the spring on the Riviera fuel door. (No pictures for now). I am not a metalsmith so this is all at your own risk. That said...
The spring that pops your door open is a thin piece of steel. When it ages/corrodes it loses its springiness and either breaks or flattens.
You can replace it by forming a spring out of a 5 to 10 mm piece of common spring steel flat stock. One way to get such a thing is to obtain an inexpensive screen door roller, mounted on a piece of spring steel. I used one like this: https://www.amazon.com/Prime-Line-Products-513-Tension-Bearing/dp/B0002YX4J8/. When you look at the picture, you'll see it already has a "W" bend in the spring. That's useful. Either a new or sued one of such a spring should work fine for this. I used a new one, because I don't have this sort of stuff laying around.
Here's how:
First, using your Dremel moto-tool with a cutoff wheel, cut the spring just about 2 to 3 mm into the bend on either side of the W. Then use the cutoff tool to round off the sharp edges of that cut so you don't cut yourself working on the thing. The point is you'll turn this side into a clip that will slide onto the base of the fuel door hinge. We'll call it the "clip side." The 3 mm gives you a tab to grab with vise grip pliers. More on that later.
Next, on the other side of the W cut the spring so that you leave a flat tang about 25mm long past the curve. That will form that "working end" part of the spring.
Then, using a pair of vise grips, crush the clip side flat, using a metal rod such as a common round screwdriver shaft as a mandrel for that bend. The point is to form the clip side such that it will grip and hold the base of the hinge. You now need to bend the outer part of the clip outward a bit so that the functioning part of the clip is about 1 cm long only (7 mm or so is OK), and leave a little outward bend on the end. Using the Dremel cut that outward bend so that what's left sticks up about 1 mm or so only, and then use the cutoff tool to round off the sharp edges of that cut so you don't cut yourself installing the thing.
Now curl the working end toward the clip side of the spring so that when it's installed the working end does not scratch up the gas door hinge but still sticks out at about a 45 degree angle. At the end you could wrap this working end of the spring in electrical tape or dip in that plastic rubber coating stuff (plastidip) --- just not yet.
Now's the time to take the new spring you made to the car and check by installing it, after you remove the remnants of the old spring. You may need needlenose pliers and a screwdriver to slide the remnants of the old spring off the hinge. You also may need to bend the clip end of the new spring out a little to be able to slide it onto the hinge. Don't worry about if you bent it too much, we'll fix that next, just *don't* bend it back and forth and back and forth because if you do it will "work harden" and break.
Now you need a small dish (an aluminum tart dish, a clean and empty baby food jar, an empty tunafish can, what-have-you) and a propane torch. And optionally some oil, cooking oil is fine, and for that matter used motor oil is OK (I will explain later), you just need 4 oz (half cup) or so -- just enough so when you drop teh spring into the dish or can it's covered completely. You're going to give a mild hardening and tempering to the spring. First: If you had to bend the clip end out to get it over the hinge base, now you need to crush it back into place with the vise grip pliers so that the gap in the clip is less than a millimeter. The point is you have to use the vice grip pliers and maybe the needlenoses to form the spring into final shape before tempering. Also, those of you who make springs for critical applications -- this spring is expected to work but not expected to last as long as the springs you make. Next, holding the spring with pliers, use the propane torch to heat it to red. YOu will have to move the torch around the spring. What you will notice is that once you get it good and hot it will stay red a bit. When hot through, then quench it by dropping into the oil. It will cool in a few minutes. If the oil catches fire just put a lid over the container to cut off the air. when cool, reheat the curved parts of the spring to a dull red then allow to air cool - this cooling will take a bit longer maybe 5-10 minutes. NOW you can put tape, heatshrink tubing or plastidip on the working end of the spring and install the clip end on the hinge. | |
| Subject: Re: Write-Up: Fuel Door Hinge Pin Repair | |
