| Installed the 3.5" pulley | |
+3RhinoFLA Mr.Riviera SpaceBar 7 posters |
SpaceBar Aficionado
| Subject: Installed the 3.5" pulley Sat Jun 09, 2007 8:53 pm | |
| Met up with Derek (deekster_caddy) today. He helped me install the pulley and tuned up the Riv today. It feels great now. Shifts much better and the response on the throttle is awesome now. Much better mod than the FWI. Only got about 2* of knock at most too. Going out tomorrow to do some more scans just to make sure. Now just waiting to hear back from intense about a cam and some headers. | |
| Subject: Re: Installed the 3.5" pulley Sat Jun 09, 2007 9:29 pm | |
| nice! so what made you choose a cam insted of rockers? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: Installed the 3.5" pulley Mon Jun 11, 2007 3:35 pm | |
SpaceBar Aficionado
| Subject: Re: Installed the 3.5" pulley Mon Jun 11, 2007 6:02 pm | |
| - Mr.Riviera wrote:
- nice!
so what made you choose a cam insted of rockers? I think I would rather have the gains all across the rpms instead of just the upper range. It looks to be more beneficial than just doing the rockers. - RhinoFLA wrote:
- what puller did you use
I went to Derek's house and he helped me with his. He has the Pulley boys puller I believe. | |
| Subject: Re: Installed the 3.5" pulley Tue Jun 19, 2007 7:57 pm | |
| Yeah, I have the pulley boys puller. It's easy enough to use although sometimes will bend up the stocker because they are so tight on the shaft. SpaceBar's pulley came off easy, totally reusable - we did two that day and the second was on a GTP and it was really tight, totally torqued the stock pulley over. | |
| Subject: Re: Installed the 3.5" pulley Tue Jun 19, 2007 11:12 pm | |
| Derek, you can stop by Fargo anytime you're passing thru, and don't forget the DHP... | |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Re: Installed the 3.5" pulley Sat Aug 23, 2008 1:18 pm | |
| I just got done installing the 3.5 mps wow it feels a lot more powerful than it was i love it lol. i already installed the autolights 104 plugs, zzp 180deg thermostat. i also removed the stock airbox and replaced it with a cone filter i also put a heat shield on the side of the filter that's facing the motor untill i can get a fwi. Also getting all 4 new bfg traction t/a tires tomorrow! | |
Chicken Aficionado
| Subject: Re: Installed the 3.5" pulley Sat Aug 23, 2008 1:21 pm | |
| Thats great! Makes a big difference, huh?
I would scan your car next to make sure your knock levels are under control.... | |
| Subject: Re: Installed the 3.5" pulley | |
