| Passenger side window. Will go up, not down. New motor. | |
dswitzer9865 Rookie
Name : Switz Joined : 2010-11-26 Post Count : 18 Merit : 0
| Subject: Passenger side window. Will go up, not down. New motor. Mon Dec 24, 2012 3:40 pm | |
| Hello- About 1 week ago...Passenger side window refused to go up on 95 riv. It will however go down. Driver side switch does nothing.
Started tearing it down...got panel off and took the motor out. It looked jacked up and corroded. Checked I was getting power to the connector to the motor and all was good. Dark blue wire means up and gray/brown wire is down. Both had power. Bought new motor and hooked it up and that refuses to roll up also but down action works also.
Does anyone have any suggestions? I am getting power to the connector so that means the switch is fine. Although I am confused on which wire is the ground wire.
Thanks, | |
bigdave Fanatic
| Subject: Re: Passenger side window. Will go up, not down. New motor. Mon Dec 24, 2012 4:37 pm | |
| I would guess that you need a new switch at the drivers side. When checking for power at the motor you need to also check that the other wire is providing ground.The switch will switch the polarity to reverse the motor. | |
dswitzer9865 Rookie
| Subject: Re: Passenger side window. Will go up, not down. New motor. Wed Dec 26, 2012 11:38 am | |
| Alright, would that explain why the driver side switch will not roll the passenger window up or down? But the passenger side switch will allow it to go down. The driver side switch is bad and is stuck in the 'down' polarity? | |
bigdave Fanatic
| Subject: Re: Passenger side window. Will go up, not down. New motor. Wed Dec 26, 2012 6:16 pm | |
| That is very possible. Do a few basic tests with a test light or multi-meter and you may be able to tell for sure. Good luck to ya! | |
jbeganny Enthusiast
Name : John Beganny Location : Litchfield, Maine Joined : 2011-09-05 Post Count : 120 Merit : 2
| Subject: Re: Passenger side window. Will go up, not down. New motor. Wed Dec 26, 2012 11:08 pm | |
| This sounds exactly like my seat problem. When you figure it out please post it so I will know what to do with my seat motor. If I come up with a remedy first I will post that as well. | |
dswitzer9865 Rookie
| Subject: Re: Passenger side window. Will go up, not down. New motor. Thu Dec 27, 2012 9:14 pm | |
| Will do. 'New' master switch is in the mail. | |
dswitzer9865 Rookie
| Subject: Re: Passenger side window. Will go up, not down. New motor. Sat Dec 29, 2012 10:32 pm | |
| The culprit was a broken wire in the harness in the doorjam....Actually 5 wires total were broken | |
bigdave Fanatic
| Subject: Re: Passenger side window. Will go up, not down. New motor. Sun Dec 30, 2012 6:55 am | |
| Good find, Were the broken wires in the left or right door harness? | |
dswitzer9865 Rookie
| Subject: Re: Passenger side window. Will go up, not down. New motor. Sun Dec 30, 2012 2:28 pm | |
| left, fixed my fuel door, unlock issues too | |
gmann3001 Fanatic
Name : Glenn W. Peck Age : 50 Location : Orland Park, IL. Joined : 2011-11-16 Post Count : 389 Merit : 9
| Subject: Re: Passenger side window. Will go up, not down. New motor. Tue Jun 04, 2013 8:34 pm | |
| I have the same window issue... Ill try the wires hopefully that fixes it. | |
| Subject: Re: Passenger side window. Will go up, not down. New motor. Tue Jun 04, 2013 11:18 pm | |
| - gmann3001 wrote:
- I have the same window issue... Ill try the wires hopefully that fixes it.
dont forget to check the switches on drivers side door... | |
| Subject: Re: Passenger side window. Will go up, not down. New motor. | |
