 missing at idle
3 posters
missing at idle Empty
PostSubject: missing at idle   missing at idle EmptyTue Dec 24, 2013 11:36 am
Noticed a couple of days ago that my buick has developed a miss at idle both in park and drive. Plugs and wires are about 5 months old. I havent changed the coil packs yet. Theres no check engine light. It doesnt hesitate under any throttle position. Do you think its my coils? IAC etc.
Merit : 149
PostSubject: Re: missing at idle   missing at idle EmptyTue Dec 24, 2013 1:01 pm
If it was a persistent miss, you would get a CEL. It would also tell you which cylinder was missing. If you scan the engine, you can look at the misfire history for all 6 cylinders. The PCM keeps track of the misfires with an actual counter. Each coil fires 2 cylinders pairs. Those pairs are called companion cylinders. On our engines, they are 1-4, 2-5, and 3-6. If the misfire history reveals misfires on a pair of companion cylinders, I'd suspect that particular coil, but not otherwise. Do some diagnostic testing before you replace parts unnecessarily. Just my .02
PostSubject: Re: missing at idle   missing at idle EmptyTue Dec 24, 2013 1:05 pm
That sounds more like dirty fuel injectors to me. I was amazed at the difference in idle quality after I had mine bench cleaned. It would miss and sometimes 'spit' a little bit. Like there was raw gas dripping into a cylinder that wouldn't fire right, and sometimes it would pop in the exhaust pipe. After clean injectors - smooth as silk.
Try disconnecting one injector at a time and see if one of them makes the idle smooth out.
PostSubject: Re: missing at idle   missing at idle EmptyTue Dec 24, 2013 1:09 pm
Yup no check engine light. Its definitely an erratic idle. WOuld a vacuum leay2k cause this? If so, what would i use to detect it. Cleaningthe injectors is a good idea
PostSubject: Re: missing at idle   missing at idle EmptyTue Dec 24, 2013 1:20 pm
And yes the tach needle does go up and down, id say no more than two tick marks. Whats the worst that can happen?
Merit : 149
PostSubject: Re: missing at idle   missing at idle EmptyTue Dec 24, 2013 1:39 pm
Just put a vacuum gauge on it. I have a vacuum/boost gauge on mine. It pulls a steady 20" of vacuum at idle, in Park, fully warmed up. Anything less than that, you have a vacuum leak.
PostSubject: Re: missing at idle   missing at idle EmptyTue Dec 24, 2013 3:04 pm
Wait a minute. My aeroforce gauge reads boost. But at idle i think it reads vacuum in the negative. Itll will jump from -19 to -17.9
missing at idle
» Missing
» Idle Problem in Drive Only - Stumbles, Shakes
» FAQ: Vacuum Hoses & Lines (Series II SC)
» missing chip in the key
» am i missing a vacuum ine
