| check oil light | |
bmcd9179 Fanatic
Name : Bryson Age : 28 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
| Subject: check oil light Sun Jan 05, 2014 7:42 pm | |
| so my check oil light comes on for 15 seconds then turns off whenever i start up my car, always when cold, sometimes when warm. my oil is well where it should be, what up with that.. | |
| Subject: Re: check oil light Sun Jan 05, 2014 8:04 pm | |
bmcd9179 Fanatic
| Subject: Re: check oil light Mon Jan 06, 2014 11:18 pm | |
| Thanks AA! I will try that, I live in 20 degrees in winter, my oil pan seems to have a small dent in it, and I change oil every 3k miles, other then that, that's all I can think of | |
| Subject: Re: check oil light Tue Jan 07, 2014 11:43 am | |
| Which light are we talking about, the oil level light, or the oil pressure light? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
bmcd9179 Fanatic
| Subject: Re: check oil light Tue Jan 07, 2014 10:59 pm | |
| The check oil level light | |
| Subject: Re: check oil light Wed Jan 08, 2014 12:29 am | |
| I thought you meant oil pressure. Might try changing the level sensor. It's on the side of the oil pan. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
bmcd9179 Fanatic
| Subject: Re: check oil light Wed Jan 08, 2014 11:16 pm | |
| sorry AA i should have been more specific, alright ill check that out and get back to this. | |
96riv Fanatic
| Subject: Re: check oil light Thu Jan 09, 2014 12:27 am | |
| Mine comes on once in a while after starting lasting 30 seconds, it has a mind of its own. I have replaced the sensor. | |
bmcd9179 Fanatic
| Subject: Re: check oil light Thu Jan 09, 2014 11:56 pm | |
| Did replacing the sensor do the trick? | |
| Subject: Re: check oil light | |
| check oil light | |
