| FAQ: Big Wheels Question.............Will they fit?! | |
+67ghpcnm Johnny5 nebstewart07 bigdave abchuuch th3fr4nchi5e stan Z-type matt270avian jbird J. Chris Davis charlieRobinson rivparadise Riviboi95 robotennis61 norsky86 Hometown Hero Rosario sqrivi Rickw YO MUDA xxsupergman25xx Abaddon brians74x ZEP VJD2 Tank Eldo ghost88 ewolfe0050 97rivsc L67 DEMonte1997 millerje18 98RIV7777 BoattailBob captshiner 1wickedninja Snowdog IBx1 TonySmooth89 deekster_caddy texasfan010 '96reese jrocha SpaceBar mcgusto82 Ridin-Rivi dreww Jack the R 99Rivman 98riv 2toneRivi Pearl Riv Jason 96riv jax95riv Andysdorm turtleman Darko 1998 Riv racinfan AA ¤DoughBoy¤ pwmin Mr.Riviera T Riley 71 posters |
charlieRobinson Expert
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Mon Mar 04, 2013 4:04 pm | |
| I guess that's what I meant.. wheel+tire. Does it need to be the same diameter as OEM? Is that the trick? | |
J. Chris Davis Aficionado
| Subject: temp Mon Mar 04, 2013 4:09 pm | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Mon Mar 04, 2013 7:37 pm | |
| The overall rolling diameter needs to be the same as stock, so revolutions per mile are the same. This thread contains a wheel & tire size comparator, so you can tell what combinations will work: https://rivperformance.editboard.com/t454-wheel-tire-lug-bolt-pattern-center-bore-infoWheel/tire combos that are compatible with our stock size of 225-60-R16 (most common arrangements are in bold): 16" wheel: 265-50-R16* 245-55-R16 225-60-R16 (OEM) 205-65-R16 195-70-R16 17" wheel: 305-40-R17* 275-45-R17* 245-50-R17 225-55-R17205-60-R17 18" wheel: 315-35-R18* 275-40-R18* 245-45-R18215-50-R18 195-55-R18 19" wheel: 315-30-R19* 275-35-R19* 245-40-R19215-45-R19 195-50-R19 20" wheel: 335-25-R20* 275-30-R20* 245-35-R20215-40-R20 185-45-R20 21" wheel: 355-20-R21* 285-25-R21* 235-30-R21 205-35-R21 185-40-R21 22" wheel: 295-20-R22* 235-25-R22 195-30-R22 * tires above 245mm width may rub fender linings & brake hoses. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Mon Mar 04, 2013 11:36 pm | |
| Thank you for the quick reference! Much appreciated! | |
jbird Fanatic
Name : Jeff Location : Cleveland area Joined : 2013-11-11 Post Count : 368 Merit : 7
| Subject: 1st up is rims Thu Dec 12, 2013 12:12 pm | |
| looking to move to a larger rim. I have searched but not found any pics or discussions on Lucerne 18's on a Riv. Do these fit, my concern really is the offset, dont want them to be in too far in. Any pics, info, opinions, would be appreciated! thanks, jbird
matt270avian Expert
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 12:39 pm | |
jbird Fanatic
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 12:49 pm | |
| Thanks for the reply!
I have been all thru that thread, saw the 17" rims. I am more interested in the 18x7.5 10 spokes, I think they look great just would love to see them on a Riv before I'd order/buy any. The stock rims fit the wheel well right, don't like if the offset/backspacing has them out or in too far. Jbird | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 12:52 pm | |
| The 18" Lucerne wheels will work and fit just fine, yes. I originally wanted the Nickel versions of those, but they're hard to come by, and still expensive used and/or refurbished. I got the wheels that are on my car now brand new for half the price of used Lucerne wheels.... | |
jbird Fanatic
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 1:30 pm | |
| - Abaddon wrote:
- The 18" Lucerne wheels will work and fit just fine, yes. I originally wanted the Nickel versions of those, but they're hard to come by, and still expensive used and/or refurbished. I got the wheels that are on my car now brand new for half the price of used Lucerne wheels....
Good to know they'll fit, I was wanting the painted version but found a good price on chrome ones...may have to keep looking. The stock rims look decent & I have good tread, patience... I have quite a bit of winter weather ahead!Thanks Jbird | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 1:36 pm | |
| - jbird wrote:
I have quite a bit of winter weather ahead! No chit. My stockers are going back on tonight before I leave the shop. I plan on driving it through the winter when the ground isn't covered in the white stuff. The winter beater Jeep is for the deep stuff | |
matt270avian Expert
| Check out the Sport Edition SE-14's. They're easier to come by, cheaper, and have a few finishes and sizes to choose from. | |
Z-type Aficionado
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 3:44 pm | |
| These wheels are good + no front license plate..Perfect. | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 4:04 pm | |
| Those wheels look nice.not too pimp not at all ricer.I bet a tri shield Buick logo would look great in place of the center cap | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 4:07 pm | |
| Oh yeah Robot....a Buick emblem in the center. | |
matt270avian Expert
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 4:20 pm | |
| He made custom "R" center caps that turned out really nice. There's pictures somewhere. | |
Z-type Aficionado
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 4:27 pm | |
matt270avian Expert
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Thu Dec 12, 2013 4:51 pm | |
| You should make another set in gold. I think it would make them look a little better. | |
th3fr4nchi5e Addict
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Fri Dec 13, 2013 12:31 am | |
| - jbird wrote:
I am more interested in the 18x7.5 10 spokes, I think they look great just would love to see them on a Riv before I'd order/buy any. Jbird Hey Jeff, theres a Riv I've seen a few times at school with the wheels I think you're referring to. I never got to talk to the owner but they look to fit nicely, and fit the styling well enough to look like they could have been an option. | |
abchuuch Special
Name : Case Location : British Columbia Joined : 2014-01-17 Post Count : 1 Merit : 0
| Subject: I'm looking to put rims on in the spring!! 22's or 20's ???? I'm torn... Fri Jan 17, 2014 6:37 pm | |
| I have had a 99 rivi for about 8 months!
I'm debating on what to do for the spring!
I'm wanting 22 inch rims and tires...
Most websites dont agree with it...
It seems i just need to go low profile on the tires and I should be fine...
ANY EXPERIENCE AND OR USEFULL INFORMATION ???????????? | |
bigdave Fanatic
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Fri Jan 17, 2014 7:34 pm | |
| The size of rims as well as the style is purely personal preference. The only concern would be clearance of the wheel well openings. | |
nebstewart07 Fanatic
Name : Ben Stewart Age : 34 Location : Schofiel Barracks, HI Joined : 2010-12-12 Post Count : 390 Merit : 6
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Fri Jan 17, 2014 9:29 pm | |
| My 20's rub when I turn the wheels completely to the right or left | |
ZEP Fanatic
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Fri Jan 17, 2014 10:14 pm | |
| I think most ppl on here would recommend at most 18s. If you do go to 22s, get ready to feel every bump in the road. Also get ready to constantly be reminded of how small the Riv's brakes look (if you get an open design).
Whatever you do, let us know how it turns out! | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Fri Jan 17, 2014 10:24 pm | |
| 22" rims will make your speedy Riv feel like it has lead bottomed boots on.Fat sluggish & clumsy. jmo. | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 37 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! Sat Jan 18, 2014 12:30 am | |
| Subject: Re: FAQ: Big Wheels Question.............Will they fit?! | |
