 Is my fuel injector bad?
3 posters
KnottyEagle
KnottyEagle
Is my fuel injector bad? Empty
PostSubject: Is my fuel injector bad?   Is my fuel injector bad? EmptyWed Nov 19, 2014 7:36 pm
When my uncle and I were pulling my fuel injectors out for the LIM gasket install, it seemed like they were never going to come off. There was so much gunk build up around them, that they were almost glued in place. In the process of changing the o-rings and cleaning them off, I noticed that where the o-ring sits, there's a little lip that you have to slip them over. I'm assuming It's just there to hold the o-ring in place, but I'm not sure. One of the injectors is completely missing it, and another has a little piece that broke off. Is this bad? Will anything bad happen?
Is my fuel injector bad? 20141118_174839_zpsgsu1a1sb
Is my fuel injector bad? 76f2e144-0613-4220-a1c6-07057ea6edbc_zps3fc44975
PostSubject: Re: Is my fuel injector bad?   Is my fuel injector bad? EmptyThu Nov 20, 2014 11:00 am
Those discs are brittle and have something to do with the spray pattern. I've seen them run with and without them and it doesn't seem to make any difference in the long run. As far as I know they aren't part of a typical injector service kit (mainly O-rings) and are pretty hard to come by.
PostSubject: Re: Is my fuel injector bad?   Is my fuel injector bad? EmptyThu Nov 20, 2014 9:21 pm
I'm not 100% sure, but I believe Mr. Injector replaces those discs as part of rebuild service. I got a set back with all intact - could've sworn one was chipped beforehand.
KnottyEagle
KnottyEagle
PostSubject: Re: Is my fuel injector bad?   Is my fuel injector bad? EmptyFri Nov 21, 2014 12:51 pm
Mr. Injector says he replaces filters, o-rings, spacers and pintle caps. I'm assuming the pintle caps are what I'm missing.
So, for $85.50 (includes shipping), I can get perfectly cleaned injectors. Hmm.
KnottyEagle
KnottyEagle
PostSubject: Re: Is my fuel injector bad?   Is my fuel injector bad? EmptyFri Nov 21, 2014 12:55 pm
$91 actually. Forgot return shipping.
» fuel line leak. need to disable fuel pump. Fuse or relay?
» Fuel Line/Fuel Rail connector leak
» Can oil leak out of fuel injector grommets?
» Fuel injector leak... weird
» Bad injector?
