 CA E85 Throwing Lean Codes in Flex Fuel Vehicles
2 posters
damnjetski
damnjetski
CA E85 Throwing Lean Codes in Flex Fuel Vehicles Empty
PostSubject: CA E85 Throwing Lean Codes in Flex Fuel Vehicles   CA E85 Throwing Lean Codes in Flex Fuel Vehicles EmptyWed Nov 19, 2014 12:28 pm
Just a heads-up from the Sunshine/ we hate you state. There's been a lot of chatter in the service side about E85 causing problems in Flex fuel vehicles over the past day or two. Apparently it's causing lean codes and making the vehicles run rough. The initial thought from everyone is that CA put in a new additive that caused the problems. I'll keep you all posted if anything else comes of it.
damnjetski
damnjetski
PostSubject: Re: CA E85 Throwing Lean Codes in Flex Fuel Vehicles   CA E85 Throwing Lean Codes in Flex Fuel Vehicles EmptyWed Nov 19, 2014 7:00 pm
False alarm. What's changed is that Flex Fuel is no longer standard in GM trucks. So if you get one without a yellow gas cap, it's not Flex Fuel equipped. Thanks to this forum, when it came up in my store, I actually knew what I was talking about, unlike one of the managers who just made the situation worse when one of our customers just assumed that his truck was Flex Fuel equipped and filled up a whole tank.
Unfortunately, this also means that GM is continuing to nickle and dime their products out of basic features that are a serious bonus for most people. The Regals with the 2.0 Turbo no longer come Flex Fuel capable and the GNX likely won't be, when it comes in 2016 or 17.
Working at GM continually makes me want to go to Detroit and hold a picket sign that says, "WHY YOU DO DIS?"
PostSubject: Re: CA E85 Throwing Lean Codes in Flex Fuel Vehicles   CA E85 Throwing Lean Codes in Flex Fuel Vehicles EmptyThu Nov 20, 2014 10:59 am
Maybe this means that E85 isn't all they cracked it up to be a few years ago?
damnjetski
damnjetski
PostSubject: Re: CA E85 Throwing Lean Codes in Flex Fuel Vehicles   CA E85 Throwing Lean Codes in Flex Fuel Vehicles EmptySat Nov 22, 2014 5:07 pm
Eh, I think it was when it was significantly cheaper than gas, but then capitalism swung too far and the decreased fuel economy made it a deal-breaker for most people. As for forced air induction vehicles like the Regal and the GNX, I can't think of a reason not to get it. It's what $300 in parts? Why not make that accessible on vehicles that will benefit from it the most?
But what do I know, I just hauk the product.
PostSubject: Re: CA E85 Throwing Lean Codes in Flex Fuel Vehicles   CA E85 Throwing Lean Codes in Flex Fuel Vehicles EmptySun Nov 23, 2014 9:06 am
Yeah, the very high octane is a bonus, but everything else about it doesn't seem that practical. I'd love to be able to buy E-0 again... but I'll have to move to another state for that.
» 1995 Buick Rivera scan codes P0171 fuel trim lean, P1406 EGR Pintle postion
» Running Lean
» fuel line leak. need to disable fuel pump. Fuse or relay?
» Fuel Line/Fuel Rail connector leak
» Fuel pressure and fuel pump
