Yardley Enthusiast
| Subject: Need Passenger Door Climate Controls Fri Sep 25, 2020 10:45 am | |
| Does anyone have a set of these? My lower dial no longer illuminates and I would like it to. | |
Yardley Enthusiast
| Subject: Re: Need Passenger Door Climate Controls Fri Sep 25, 2020 11:02 am | |
| Jeezis. There's a thousand of them on ebay. Thanks. | |
| Subject: Re: Need Passenger Door Climate Controls Fri Sep 25, 2020 7:34 pm | |
| - Yardley wrote:
- Jeezis. There's a thousand of them on ebay. Thanks.
Actually, it's pretty easy to simply replace the bulb(s) once you remove the control from the door panel. They are very similar to the bulbs in the main climate control - the climate control write up tells you what color and where to get the lacquer to paint the bulbs with as well as the bulbs, and how to replace them on a printed circuit board. When you take the door controller apart (it's obvious) you'll easily access the board. I did it to mine last year. I was embarrassed to learn I had a bulb in there that never did work for the time I owned the car - fixed! I just replaced them all I think there were two or three. Once you have the controller off the door panel it might take you the same or less time to replace a bulb than it did to read this post. Albertj | |
| Subject: Re: Need Passenger Door Climate Controls | |
