| Steering Wheel Removal Nightmare | |
MontyHaul53 Special
Name : MontyHaul Location : Alamo City Texas Joined : 2019-12-27 Post Count : 8 Merit : 0
| Subject: Re: Steering Wheel Removal Nightmare Sun Dec 29, 2019 3:55 pm | |
| Hi,MontyHaul53.Don`t know why but I can`t see pics! Tried everything but still.... If you can repost. | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Sun Dec 29, 2019 4:05 pm | |
| Let me double check to put them into a working file and post the update. | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Sun Dec 29, 2019 4:34 pm | |
| Subject: Re: Steering Wheel Removal Nightmare Sun Dec 29, 2019 6:39 pm | |
| cool Monty.....yeah , now I can see .Let me look. | |
| Subject: Re: Steering Wheel Removal Nightmare Mon Dec 30, 2019 9:26 am | |
| I have a red SW complete I'd send you for short money and postage. If interested send a PM. You could have it recolored by a steering wheel repairer.  You'll have to shop around for that, the only one I know is craftcustoms.com, they can add wood or carbon fiber tot he wheel as an overclad/trim. Or for about $30.-  you can recolor/refinish it yourself, see http://www.leatherique.com/steering-wheels.html. Another $70 or so gets you the leather, right color and brand new, from Wheelskins (wheelskins.com) | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Fri Jan 03, 2020 10:25 am | |
| Over the Holiday I was able to obtain a good SW at the same salvage yard here in Texas. I'll have to get it re-dyed. I have made several other attempts to remove the back ring from the column but no success. Even trying to push it back on hasn't worked. Any ideas? | |
| Subject: Re: Steering Wheel Removal Nightmare Fri Jan 03, 2020 1:36 pm | |
| Ohhh yeah Month. Keep us informed. I'm very interested. | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Fri Jan 03, 2020 4:50 pm | |
| I did find this like in a jeep Forum on a similar issue (with photos).
https://www.jeepforum.com/forum/f13/broken-steering-wheel-hub-stuck-shaft-3152281/
Looks like I've got my work cut out for me. | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Sun Jan 05, 2020 11:56 am | |
| Spent too much time trying to find a 2 jaw puller that would work so took thing in my own hands and carefully destroyed the clock spring behind the stuck rear steering wheel hub, removed the snap ring, grabbed my trusty 2 jaw large puller (which now fits perfectly behind the hub), and two strokes on the torque wrench, had it finally free! Put the salvaged CS on and am starting to put everything back together today with fingers crossed. What a P-I-T-A! -MontyHaul | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Sun Jan 05, 2020 6:01 pm | |
| Finally back together. Horn still doesn't work without using my bypass button. Still will need to send SW out to be refurbished, but all the RDO controls work on this salvaged AB. To Do: Cruise Cntrl, AC, Drivers tilt seat motor (going soon), SC snout bearing refurbish kit (already purchased), Rear side interior panel recover with Tan to cover salvaged panel we just picked up. Wife really loves this car of hers and I'm doing everything to keep her (Riviera) together! [url=https://flic.kr/p/2iaEGFL[/url] | |
EyeDoc1 Enthusiast
Name : Christen Location : Vancouver, WA Joined : 2016-03-30 Post Count : 125 Merit : 5
| Subject: Re: Steering Wheel Removal Nightmare Thu Jan 09, 2020 5:30 pm | |
| In a quick nutshell, how tough is it to just pull the steering wheel off. I think I know of one in a junkyard, but from a '96. I think I"m going next weekend as we have 3 in the yard, 95-97. Rare event. | |
MontyHaul53 Special
| Subject: Re: Steering Wheel Removal Nightmare Fri Jan 10, 2020 11:18 am | |
| Type in Google or whatever you use "98 Buick steering wheel removal" and there are several YouTube videos that will help. I didn't find the directions in the Write-Up's. Key here is to disconnect the battery and pull the AB fuse and leave it for about 30min.'s before you start the removal process. I wouldn't use an impact wrench to remove the wheel nut as I did, just use a regular wrench instead. A standare steering wheel pulley will do the trick. | |
EyeDoc1 Enthusiast
| Subject: Re: Steering Wheel Removal Nightmare Fri Jan 10, 2020 11:36 am | |
| No doubt. Since the cars are in the junkyard, no worries. But good advice anyway. YouTube is a Godsend these days, and I sure appreciate all the advice dispensed and tips/tricks that help you learn from other peoples discoveries or mistakes. | |
| Subject: Re: Steering Wheel Removal Nightmare | |
