71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: Re: Flashing temp on climate control unit? Wed Feb 19, 2020 4:41 pm | |
| Today I put a new actuator in blinking stopped on start up so if u have blinking its a bad actuator it was a delco CHINA this time I got a four seasons for a 1/3 of the price that is a PITA JOB to have to do twice. | |
| Subject: Re: Flashing temp on climate control unit? Wed Feb 19, 2020 6:43 pm | |
| - 71stagegs wrote:
- Today I put a new actuator in blinking stopped on start up so if u have blinking its a bad actuator it was a delco CHINA this time I got a four seasons for a 1/3 of the price that is a PITA JOB to have to do twice.
YES 'tis a PITA. I have actuators to replace as well - the ones on the passenger side are good, the ones on the drivers side not so much. They work but not consistently, last time this happened it was cracked gears. Hopefully before Friday, I have a long drive coming up. also I have a TB to overhaul and install. And so on, and so on... Albert | |
| Subject: Re: Flashing temp on climate control unit? Wed Feb 19, 2020 9:43 pm | |
| Albert the drivers side SUCK take the front seat out u can laid down and get under there. Good luck | |
| Subject: Re: Flashing temp on climate control unit? Wed Feb 19, 2020 11:10 pm | |
| - 71stagegs wrote:
- Albert the drivers side SUCK take the front seat out u can laid down and get under there. Good luck
Oh... i was gonna pull the instrument cluster...? taking out the front seat sounds much better... | |
| Subject: Re: Flashing temp on climate control unit? Thu Feb 20, 2020 1:38 pm | |
| I'm sure this doesn't need to be said, but be sure to pull the airbag fuse first. | |
| Subject: Re: Flashing temp on climate control unit? | |
