| driver side mirror | |
Rivieraz Enthusiast
Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08 Post Count : 227 Merit : 1
| Subject: driver side mirror Thu Aug 13, 2020 12:24 am | |
| I found a fully functional driver side mirror (with working glass)are they hard to replace? how long does the glass last and is there anyway to prolong its life? would covering it when parked help? | |
| Subject: Re: driver side mirror Thu Aug 13, 2020 12:57 am | |
| You found the complete assembly including the housing.? Does it need to be painted to match your car.?
Assuming it's the complete assembly I would just install it and be grateful that you found one.
If it is just the glass assembly, is it a heated and dimming mirror.? If so, be EXTREMELY careful trying to replace the glass into your existing housing.
I bought a perfectly good used mirror, heated and dimming for my 98 and was successful in removing the old glass but unsuccessful installing the new/used glass part. I broke the glass and was not happy nor was I able to find another replacement unit with a heater and dimming capability.
So I just bought a cheap plain mirror and glued it to the old mirror and lived with it.
Costly mistake on my part.
Just a heads up for you. Others on this forum can better explain the best way to install just the mirror glass without breaking it. I've proven I'm not a reliable source of info. just thought I'd share my mistake with you.
To answer your question, No I do not think covering it up will prolong the life of the tint, if that's what your asking. | |
DeepFrozen Fanatic
Name : Dmitry Joined : 2016-08-28 Post Count : 252 Merit : 11
| Subject: Re: driver side mirror Thu Aug 13, 2020 2:51 am | |
| I move the mirror so there is a gap between the mirror and its housing and then use heat gun to carefully warm up everything inside. The same trick before installation, along with greasing both posts and sockets. That way, I believe, I minimize chances of breaking anything. I have removed/installed mirrors on both sides, zero broken glass so far. My '97 doesn't have dimming/heated mirrors, so I'm planning to install Aurora heated mirrors - the glass assembly only, I mean. Where I live, Aurora parts are easier to find.
Rivieraz Enthusiast
| Subject: Re: driver side mirror Thu Aug 13, 2020 2:54 am | |
Rivieraz Enthusiast
| Subject: Re: driver side mirror Thu Aug 13, 2020 2:55 am | |
| I believe the color of my car is Adriatic blue.how can I find the exact color | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8616 Merit : 180
| Subject: Re: driver side mirror Thu Aug 13, 2020 8:10 am | |
| - Rivieraz wrote:
- I believe the color of my car is Adriatic blue.how can I find the exact color
Paint shop will mix it for you and put it in a (good quality) rattle can. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: driver side mirror Thu Aug 13, 2020 10:38 am | |
Look at the underside of the spare tire cover in the trunk. There is a label listing all the options on the car. At the bottom of the label, next to BC/CC is the paint code. https://www.automotivetouchup.com/images/paint-codes/buick-paint-code-label-1.jpg _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
Rivieraz Enthusiast
| Subject: Re: driver side mirror Thu Aug 13, 2020 12:09 pm | |
| Subject: Re: driver side mirror Thu Aug 13, 2020 4:40 pm | |
| - Rivieraz wrote:
- I found a fully functional driver side mirror (with working glass)are they hard to replace? how long does the glass last and is there anyway to prolong its life? would covering it when parked help?
My driver side outside mirror was fine until about 2009 when I changed jobs and didn't park in a garage all the time. It took a few years to turn gold. After about 12 years in outdoor use, it now has 'double vision.' My wild guess is that covering it might not work; on a BMW forum I read the failure is due to *heat.* | |
| Subject: Re: driver side mirror Thu Aug 13, 2020 4:46 pm | |
Rivieraz Enthusiast
| Subject: Re: driver side mirror Thu Aug 13, 2020 11:24 pm | |
| well as long as I don't expose it to a lot of sunlight or heat it will be fine.LOL also I'm not sure if mine had heat but the new one does will it complicate installment? | |
| Subject: Re: driver side mirror Sun Aug 16, 2020 1:47 pm | |
| - Rivieraz wrote:
- well as long as I don't expose it to a lot of sunlight or heat it will be fine. LOL also I'm not sure if mine had heat but the new one does will it complicate installment?
AFAIK all the auto-dim mirrors had heat. The heater does not get all that hot, BTW. | |
| Subject: Re: driver side mirror Sun Aug 16, 2020 2:37 pm | |
| - Rickw wrote:
Assuming it's the complete assembly I would just install it and be grateful that you found one. I take it the Riv mirror is different than the Aurora mirror? | |
| Subject: Re: driver side mirror Sun Aug 16, 2020 10:31 pm | |
| - Jack the R wrote:
- Rickw wrote:
Assuming it's the complete assembly I would just install it and be grateful that you found one. I take it the Riv mirror is different than the Aurora mirror? Yes. Surprisingly, for all it's gee-whiz gizmos the Aurora did not have an autodim exterior mirror, just heat. | |
| Subject: Re: driver side mirror Sun Aug 16, 2020 11:29 pm | |
| Are all Riv mirrors auto-dim? | |
Rivieraz Enthusiast
| Subject: Re: driver side mirror Sun Aug 16, 2020 11:38 pm | |
| hmmm? I think I leaped before actually looking?i didn't check the part number,i just read the listing it has the wavy lines at the bottom right pointing up, 25627688 is what I bought and was listed as OEM...NOS, its on gm parts but it doesn't mention dimming, chalk it up to a learning experience
| Subject: Re: driver side mirror | |
