 Door Handle Pin?
3 posters
Yardley
Door Handle Pin? Empty
PostSubject: Door Handle Pin?   Door Handle Pin? EmptyMon Sep 21, 2020 8:06 pm
Any ideas on what I can use to replace this pin once I remove it? I need to transfer this spring to the handle currently on my car. I "might" be able to save this and reuse it, but if I can't, does anybody have any idea on what to use? I suppose a nail of some kind but it would need to be able to mushroom on the end.
Door Handle Pin? Door_h10
http://www.1badriv.com
DeepFrozen
PostSubject: Re: Door Handle Pin?   Door Handle Pin? EmptyTue Sep 22, 2020 5:25 am
A bolt of the right diameter will do, I guess. No need for mushrooms - just a nut )
Merit : 180
PostSubject: Re: Door Handle Pin?   Door Handle Pin? EmptyTue Sep 22, 2020 8:43 am
Usually those pins are pressed into place with an arbor press using a drift of the right size.  Set in plastic like that you probably don't want to use a hammer, the old plastic may/will shatter from the shock of the hammer blows.
What year is your Riv? Mine is a 98 and the back of the drivers door handle looks like this:
Door Handle Pin? 79101-10
Dorman 79101.
Yardley
PostSubject: Re: Door Handle Pin?   Door Handle Pin? EmptyWed Sep 23, 2020 12:56 pm
Mine is a 98. That handle is from a 96, so it is different. I was able to use the 96 spring on my 98. There was enough extra length, so I nipped the end off the shaft/pin of my 98, replaced the spring, then I used a dremel to cut a slot in the end of the pin, then used a cold chisel to peen/mushroom the ends out a bit. Works like a charm.
Door Handle Pin?
» Polished SS door handle cover to hide door panel seam separation
» Door Hinges
» Welding a car door?
» Door Protectors..
» Door locks
