 Rain water filling floorboard on passenger side of Momma's Riv.
4 posters
slugranch
Rain water filling floorboard on passenger side of Momma's Riv. Empty
PostSubject: Rain water filling floorboard on passenger side of Momma's Riv.   Rain water filling floorboard on passenger side of Momma's Riv. EmptySun Sep 27, 2020 12:51 pm
about a month ago I blew all of the fir needles in the cowling under the windshield. We hadn't had any significant rain in quite a while, but we got a downpour a few days ago and it filled the floorboard on the right side of her car. We checked it and found that the water was running down the inner door panel up forward near the hinges and the down onto the floorboard. I've checked all of the gaskets around the door, and silicone sprayed them, and wiped them all down after spraying them. anyone else ever have this problem? Driver's side is bone dry. I'm hoping that I didn't cause the problem.
Merit : 149
PostSubject: Re: Rain water filling floorboard on passenger side of Momma's Riv.   Rain water filling floorboard on passenger side of Momma's Riv. EmptySun Sep 27, 2020 3:42 pm
There are drains for the moon roof that if blocked will do that. I think there is one at each corner of the opening?
Merit : 180
PostSubject: Re: Rain water filling floorboard on passenger side of Momma's Riv.   Rain water filling floorboard on passenger side of Momma's Riv. EmptySun Sep 27, 2020 9:42 pm
The cowl drain would be blocked as well if enough of those needles got past the screen in the vent.  It's unlikely, however. The drain exits are behind the trailing edge of both front fender liners, little rubber flaps. Have a look.
brutusk1
PostSubject: Re: Rain water filling floorboard on passenger side of Momma's Riv.   Rain water filling floorboard on passenger side of Momma's Riv. EmptyFri Oct 02, 2020 4:58 pm
I think I had the same problem as you.  Have you checked page 4 of this FAQ thread?  I found a solution that worked for me.
https://rivperformance.editboard.com/t6869-faq-wet-carpet-interior-leak-problems?highlight=interior+water+leaks
» FAQ: Wet Carpet - Interior Leak Problems
» condensation under the rear seat / floorboard
» 95 rivi driver side lock, passenger side window no ground!!!!!
» FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side
» Passenger side AC blows at 60F, Driver's side at about 73F, AC set to 60F
