Name : Cliff Joined : 2020-09-01Post Count : 133 Merit : 1
Subject: Vacuum elbow Sat Dec 12, 2020 11:50 am
96 model. Anyone know where to find or how to make this vacuum elbow? Thanks
Cliff96 Enthusiast
Subject: Re: Vacuum elbow Sat Dec 12, 2020 11:51 am
It connects to the throttle body and is a different size on each end
Rivieraz Enthusiast
Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08Post Count : 227 Merit : 1
Subject: Re: Vacuum elbow Sat Dec 12, 2020 12:56 pm
the vacuum hose on my 95 is a s shaped vacuum with 2 different diameters it kept sliding off. if the rubber is good but not staying on the line where it connects too .i used xtra small hose clamps to stay in space
Cliff96 likes this post
Cliff96 Enthusiast
Subject: Re: Vacuum elbow Sat Dec 12, 2020 1:22 pm
The boot is cracked but I just put some rtv on it and once that sets i will put it back on and clamp it if i cant work out a replacement fitting
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8604 Merit : 180
Subject: Re: Vacuum elbow Sat Dec 12, 2020 9:23 pm
I used 2 pieces of (reinforced) fuel line of correct ID and glued them together with tire patch cement by cementing about 5 mm of the larger hose over the smaller. Instead of that gluing you could use a plastic or brass adapter nipple. The smaller line, I used a somewhat longer piece (maybe an inch or so longer than the original) so I could make the bend without kinking.
Rivieraz Enthusiast
Subject: Re: Vacuum elbow Fri Oct 15, 2021 3:25 pm
