Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08Post Count : 227 Merit : 1
Subject: blower wont stop Thu Aug 05, 2021 11:41 am
driving my car for about an hour today with my ac on but when i parked it the blower at your feet wont stop blowing so i disconnected the battery to shut it off. isit the blower resistor? thanks for reading. i hope everyone is happy n healthy
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8606 Merit : 180
Do you have any wiring modifications (even if they seem unrelated)?
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2186 Merit : 149
Rivieraz Enthusiast
albert none that know of ,not that its related but even the security system works correctly....thanks again LARRY70GS....
Subject: Re: blower wont stop Sat Aug 07, 2021 11:35 am
With no wiring mods then for sure it's either the blower module, or the little resistor network in the control unit.
The blower module is basically a power transistor and the resistor network changes the bias on that transistor to control fan speed. The original resistors GM used work, but get mad hot in service and eventually burn themselves off the board or fail. First time I had this problem, I opened my control unit and swapped in a set of resistors designed not to get so hot. Eventually the blower module failed, and I replaced it as I said with a junkyard unit. I was going to just replace the transistor but they were made obsolete some time ago. Substitution would be a major project because you'd have to figure out how to mount and heat-sink the replacement, including somehow reusing the epoxied terminals.
There is a post elsewhere on this site, a write up I think, about re-doing the resistors in the control unit.
For the blower module either buy one new or get one from a junkyard. My blower module failed a couple years ago, I put in a module I'd salvaged from a Riv I got a nearly-new blower motor from (that is how I leaned never to get a VDO HVAC blower, they are mad noisy).
dAriel49 likes this post
Rivieraz Enthusiast
Subject: Re: blower wont stop Sat Aug 07, 2021 11:33 pm
ACDELCO 1571971 {#12368388} GM Original Equipment .......FOUR SEASONS 20337 {#12368388, 52470336} Power Module Info One of our most popular parts Module; w/ Automatic Temperature Control (you can set a specific numeric temperature)... i bought the four seasons because it said automatic temp control but is there a difference? i usually stay with ac delco
Last edited by Rivieraz on Sat Aug 07, 2021 11:40 pm; edited 1 time in total (Reason for editing : part #)
Subject: Re: blower wont stop Mon Aug 09, 2021 9:16 am
I don't think there is any difference.
I think you would be wise to have a look in the HVAC control head.
Rivieraz Enthusiast
My friend is looking at this Riv project with blower and AC issue. The owner think it's the blower module. We'll just finish installing the brake kit and xd wheels on the truck this weekend and we'll take a closer look at it.
Rivieraz Enthusiast
Subject: Re: blower wont stop Thu Nov 04, 2021 1:10 am
