Name : Mike Arthur Age : 71 Location : Muscle Shoals Alabama Joined : 2021-08-09Post Count : 8 Merit : 0
Subject: Welcome,and need help. No overdrive or cruise Mon Aug 09, 2021 11:10 am
Hello,and thanks for the add. I've got a "new-to-me "1995 Riviera, one owner,with290,000 miles. Regularly serviced. My problem is that when I first got my baby,the traction, abs,lights were on. Also,my speedometer would stick at 58 mph. But,my cruise worked,and I had overdrive. But,after a 400 mile trip, I lost cruise and overdrive. Goes no higher than 3rd gear. Any ideas?
Subject: Re: Welcome,and need help. No overdrive or cruise Mon Aug 09, 2021 1:14 pm
It may take a while to get your car straight.
Your transmission should set a code for losing the TCC lockup, such as TCC STUCK OFF I think it's P0740.
If you lose 4th gear (or TCC lockup for that matter) your next stop is a transmission repair shop unless you work on transmissions yourself.
About your ABS and traction lights - can't diagnose this properly from afar, either. Could be a bad wheel sensor. You can check each one with a voltmeter, or someone with a Tech II or later GM diagnostic tool can read the sensor outputs and pinpoint the bad one. Fix requires changing each wheel hub that is found to have a bad sensor, after checking the wiring to determine if that's actually the problem - if you do any highway driving, Do Not Cheap Out on the hubs.
About your speedometer sticking, I have no idea.
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2184 Merit : 149
Subject: Re: Welcome,and need help. No overdrive or cruise Mon Aug 09, 2021 5:03 pm
First, check the simple things. Inspect the wiring to each wheel sensor at each wheel. Repair any damaged wires or corroded plugs. Next, put a jack under each front wheel and jack under the control arm enough to get the tire off the ground. Try to wiggle the tire side to side, and top to bottom. If you can feel any play, you need a hub bearing. When the bearing goes, they usually produce a hum or growl that increases with speed. When the bearing gets bad enough, it wipes out the sensor, which turns the ABS light and Traction Off lights on. I also had some corrosion in the harness plug for the rear ABS sensors. I had to replace the pins and rewire it to fix the ABS light that resulted from that.
mrdronenut likes this post
Subject: Re: Welcome,and need help. No overdrive or cruise Mon Aug 09, 2021 5:09 pm
I had a transmission problem when my battery went. The resultant low voltage put the transmission into limp home mode. The transmission was stuck in 3rd gear, no OD or lock up. It felt like the transmission was slipping because of the 3rd gear and no lock up. It was stalling the converter much higher. This occurred in the winter on a hard cold start. As soon as the engine warmed up, I could shut the engine down, wait a few seconds and restart, and the transmission was fine. That battery was 11 years old and owed me nothing. I replaced it and everything was fine.
Subject: Re: Welcome,and need help. No overdrive or cruise Mon Aug 09, 2021 5:12 pm
My speedometer also sticks at 58 MPH. It will stick there as I go faster, then suddenly jump to 70 MPH. I never really cared that much to even try and diagnose/fix the issue. I can tell how fast I am going by looking at the tachometer. 1600 = 60 MPH, 2100 = 80 MPH in my 98. Monitoring the speed sensor with my scan tool shows the correct speed even while the speedometer is stuck, so it seems like a mechanical problem in the speedometer head.
mrdronenut Special
Subject: Re: Welcome,and need help. No overdrive or cruise Thu Aug 12, 2021 12:53 pm
Thanks for your help. After replacing the right front hub,modulator valve, and transmission speed sensor, the general consensus from the repair shops,and scrap yards,the ECM is the next rhing I'm replacing. After removing the old one, it has "scrap-yard"writing on it. So,I've ordered a reman with a one year warranty.
Subject: Re: Welcome,and need help. No overdrive or cruise Thu Aug 12, 2021 1:13 pm
I think Larry's onto something with the real-time reading off a scan tool - might/should ask your mechanic to connect the scan tool to the car and take it for a ride while logging. The mech will soon be able to tell if it's the ECM (the reading will jump the same) or not (reading will go up and down with RPM and so on).
My guess is you'll end up at:
Southern Speedometer 13625 50th Way N. #6 Clearwater, FL. 33760 727-341-1222
They do repairs and calibrations on mechanical and electronic speedos.
Subject: Re: Welcome,and need help. No overdrive or cruise Thu Aug 12, 2021 2:53 pm
Another thing that tells me it is the head is that if I smack the lens with my fingers, the needle moves.
mrdronenut Special
Subject: Re: Welcome,and need help. No overdrive or cruise Thu Aug 12, 2021 2:59 pm
My speedometer is the least of my worries. I've got to get my overdrive and cruise working. The speedometer is not that important. My abs,traction,and check engine light stays on,and after a 400 mile trip to South Carolina, my overdrive and cruise quit. That's my focus right now.
Subject: Re: Welcome,and need help. No overdrive or cruise Fri Aug 13, 2021 11:41 am
What do you plan to do next?
mrdronenut Special
Subject: Re: Welcome,and need help. No overdrive or cruise Fri Aug 13, 2021 11:42 am
Remanufactured ECM
mrdronenut Special
Subject: Re: Welcome,and need help. No overdrive or cruise Mon Aug 23, 2021 12:14 pm
mrdronenut wrote:
Remanufactured ECM
Got a reman from FLASHMASTERS in Cincinnati. First one didn't fix it. It had #1 misfiring. Contacted them,they immediately sent a replacement with a return label for the bad one. Highly recommend these people. I now have overdrive, 4th gear,and passing gear. Also,I've got cruise control back. Amazing how a bad ecm can drive you crazy,replacing parts,until you've just gotta go to the "brain box"that tells everything what to do.
Subject: Re: Welcome,and need help. No overdrive or cruise Mon Aug 23, 2021 12:49 pm
mrdronenut wrote:
mrdronenut wrote:
Remanufactured ECM
Sounds good.
I don't recall (in ~10+ yrs) anyone else having this problem on a Riv.
ADDvanced likes this post
