 EGR Leak
2 posters
holland426
EGR Leak Empty
PostSubject: EGR Leak   EGR Leak EmptyThu Sep 16, 2021 11:19 pm
Hi, I have a 96 Buick Riviera with the 3800 Supercharge after taking off the EGR valve to clean it I noticed a leak coming from the passage on the side nearest the valve. I have tightened the nut down as much as I can with a wrench (not enough space for a torque or socket wrench) and there is still a leak. Any ideas on how to fix the leak?EGR Leak 20210912
EGR Leak 20210911
EGR Leak 20210910
Merit : 149
EGR Leak Empty
PostSubject: Re: EGR Leak   EGR Leak EmptyFri Sep 17, 2021 8:51 am
That looks like the EGR line.
https://www.rockauto.com/en/catalog/buick,1996,riviera,3.8l+v6+supercharged,1022038,exhaust+&+emission,egr+line,12319
https://www.rockauto.com/en/moreinfo.php?pk=8875168&cc=1022038&pt=12319&jsn=456&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhFUNxSQbBt9FEuOpKheaSVujQQQ4UWses1J3xhfoGup4OBaCW%2FJQcT%2BbPC1FlQhMgLhaRLyX2e%2BYi7TPLWuWLj0E0b%2FEiVDWYpvOdO62a1nHIpVO6GSjTjFL9TPl6vdKIby5juj0tu%2BO9uWEd%2Fvf1S0obxGhSLovB1TmRPo%2FS3zTrw2RnZ22pCSZOto4QgC4j0sYJaTNoFUmzmO6rdggBHwNPdDD1PxThPhWW8xxzccqm4qmIzazqT9V7t5eTdoCyWXjTRQ0CcUR9N8zM8NKcOq3PQ%2FhJOCeS
If yours is in good shape, I would unbolt it and do one of two things. Either use some high temperature RTV, or, buy some exhaust gasket material and make a gasket.
EGR Leak
» Oil leak...from where???
» Write-Up: Lower Intake Manifold (LIM) Gaskets
» Coolant leak
» Radiator / Coolant Leaks
» FAQ: Wet Carpet - Interior Leak Problems
