 Radio issue 95 Riviera
2 posters
Ro9beam
Radio issue 95 Riviera  Empty
PostSubject: Radio issue 95 Riviera    Radio issue 95 Riviera  EmptyMon Nov 15, 2021 8:30 pm
Recently purchased a 95 Riviera..has the concer ii.. the car had been sitting for awhile..when i first checked it out the antenna worked.. never did check radio though.. the antenna now does not come up. When i power on the radio a prexisting radio station shows up briefly with the volume showing 4 dashes.. then it goes to blank dashes.. Clock i assume.. i can put a cassette or cd in and eject.. but none of the volume controls work ..steering or deck mounted.. no sound of course.. and the other buttons do nothing...etc.. any ideas?
Ro9beam
PostSubject: Re: Radio issue 95 Riviera    Radio issue 95 Riviera  EmptyTue Nov 16, 2021 9:01 pm
Should the sound system still function if the power antenna does not operate..cd ..cassette..still play..etc?
Merit : 149
PostSubject: Re: Radio issue 95 Riviera    Radio issue 95 Riviera  EmptyWed Nov 17, 2021 11:40 am
Yes, regardless of the antenna function, the radio should function. Sounds like the radio is defective.
» Power Antenna/Radio Issue
» 1995 buick riviera radio
» 95 antenna issue
» Write-Up: Installing Double DIN head unit in '96-99 Riviera
» FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On
