 Is there still an option Is for rear cradle mount bushings?
2 posters
carguy8888
carguy8888
Is there still an option Is for rear cradle mount bushings? Empty
PostSubject: Is there still an option Is for rear cradle mount bushings?   Is there still an option Is for rear cradle mount bushings? EmptySat Nov 20, 2021 9:39 am
I have a loose or rubber knocking feeling when I go over decent size bumps in the rear suspension. My shocks and mounts are original & really ugly so I'm going to change them. I would like to do the rear cradle bushings at the same time but I looked and they're nowhere. Is there any solutions or advice, have a great day everybody.
Merit : 180
PostSubject: Re: Is there still an option Is for rear cradle mount bushings?   Is there still an option Is for rear cradle mount bushings? EmptySat Nov 20, 2021 9:47 pm
...while you are at it check the (top) spring perches very carefully.
carguy8888
carguy8888
PostSubject: Re: Is there still an option Is for rear cradle mount bushings?   Is there still an option Is for rear cradle mount bushings? EmptySat Nov 20, 2021 9:55 pm
For rust and cracking?
Merit : 180
PostSubject: Re: Is there still an option Is for rear cradle mount bushings?   Is there still an option Is for rear cradle mount bushings? EmptySun Nov 21, 2021 1:10 pm
Pretty much. Springs should be centered on the tops and bottoms, else you have a rusted perch and need to remove the spring and repair the perch.
carguy8888
carguy8888
PostSubject: Re: Is there still an option Is for rear cradle mount bushings?   Is there still an option Is for rear cradle mount bushings? EmptyMon Nov 22, 2021 8:05 pm
I'll make sure they're looked at when the shocks are out, thank you.
» In Need of Cradle Mount Bushings
» Write-Up: Subframe/Cradle Mount Insulators & Bushings
» FAQ: Engine/Transmission Motor Mounts
» Rear suspension bushings please
» rear shocks, bar and bushings
