Name : Joseph Contardi Location : North East PA Joined : 2021-05-21Post Count : 38 Merit : 2
Subject: 95 Riv hard starting only when hot Mon Mar 21, 2022 10:01 pm
Hello Gents,
My daughters supercharged 95 starts great when cold, but cranks lots to start when warm after sitting a bit.
Fuel pressure regulator seams to be working right.
Any suggestions?
Thank you
Subject: Re: 95 Riv hard starting only when hot Tue Mar 22, 2022 9:26 pm
redbaron wrote:
Hello Gents,
Any suggestions?
Thank you
Wondering how you tested the FPR - please elaborate.
By the way...if that FPR is original, or a replacement more than 2 years old, I'd replace it anyway and see what happens. There is a reason the replacements are cheap - because they don't last all that long. In my experience if you don't have a Delphi or Bosch FPR you're kinda hosed after a couple years. (easy tell - the good ones are made of stainless steel. The rest are yellow chromate coated. If you have a chromated one just replace it). I've gone through 2 Standard FPRs, neither has lasted more than 2 years. The replacement Bosch FPRs I've actually pulled out of junkyards, they have lasted 5+years each for me. The one I have in now was pulled out of a 200-something Park Avenue with the SC3800.
Other than the FPR, sounds like a fuel pump or (highly unlikely) fuel filter problem. Do you know how to test for those?
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Tue Mar 22, 2022 9:45 pm
Dear Eleanor,
I tested the fpr with a pressure gauge when cold. disconnecting vacuum agreed with correct operation. Was the prime suspect.
I agree with you on replacing it.
I'll let you know how it goes.
Nice Car!
Thank you Joe from PA
96 Riv daily driver
Subject: Re: 95 Riv hard starting only when hot Thu Mar 31, 2022 11:12 am
redbaron wrote:
Dear Eleanor,
Nice Car!
96 Riv daily driver
The other test, Joe, is drive the car to warm then stop the car and pull the FPR. It does not take long, as you know you just need snap ring pliers and a good grip on the little can to pull it out of the fuel rail socket. See if you can drain gas out of the vac side of the FPR. If so, chuck it and install a new one.
When the FPRs that I have had went bad, the car acted like it had a bad fuel pump. But jumping the fuel pump, it ran fine cold or warm. What is happening is that the FPR fills a bit with gas as you're running, which fools the fuel system into starvation. Turn off the car and let it cool, the fuel bleeds back outta the FPR. Wash, rinse, repeat.
Pretty much any parts store FPR will work at first but again, they die *quickly* so what you can do is go ahead and get one then buy a good one off RockAuto.com or at a GM dealer, or even take your chances on a junkyard pull (just read the pressure rating off the little can). But be careful. The dealer lists a GM 24506988 at $157.- but it's for the NON-supercharged Riv. It will run and cruise more or less OK but it is the wrong pressure and you'll notice in highway passing or freeway merges. Really, you want the 3.8 Bar unit. The Delphi FP10377 is the one you want, it is a 3.8 bar unit. FYI One that will fit is for the Mercedes 300E, but it is a 3.5 bar unit, which is 100% OK for the non-supercharged engine on the Riv. Their # is Y0280160593 for the 1992 - 2005 Merc 300E. Bosch (the OEM for the Riv's fuel injection) is kinda like GM in that they don't create with impunity any new designs for hard mechanical parts. Like an FPR.
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Thu Mar 31, 2022 10:01 pm
Hi Albert,
I did already purchase a FPR from Rock Auto. Didn't have time yet to install. Hoping Saturday.
Thank you again for this valued information.
Joe
Subject: Re: 95 Riv hard starting only when hot Thu Apr 07, 2022 4:43 pm
redbaron wrote:
Hi Albert,
Joe
bump
what's status?
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Thu Apr 07, 2022 7:14 pm
Hi Albert,
I realized I needed a 90 degree snap ring pliers. Got one. Amazon Am planning to install Saturday.
Thank you
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Wed Apr 13, 2022 9:04 pm
Hello Albert,
I replaced the FPR Saturday. My daughter didn't have trouble starting until today.
Back to square 1 again I guess.
The fellow I bought the car from last year said the fuel pump was new. Not sure if I should suspect that.
Thank you Joe
Subject: Re: 95 Riv hard starting only when hot Wed Apr 13, 2022 9:49 pm
redbaron wrote:
Hello Albert,
Thank you Joe
Your daughter's 95 Riv is almost 28 years old, and on cars it's not unusual to have multiple systems fail at this age. Some parts are engineered for "life of the car" but for most cars that's 10 years/150,000 miles or so. Some are engineered for more.
So... you are not back to square one; you did get some improvement. But... Did you ever measure fuel pressure at the fuel rail? Did the guy you bought the car from ever replace the crank sensor?
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Thu Apr 14, 2022 7:22 pm
Albert,
I did inspect fuel pressure. Looked good.
I agree the crank sensor makes lots of sense... Behind the harmonic balancer right?
Thank you for your help!
Hope you have a blessed Easter.
Joe
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Thu Apr 14, 2022 7:24 pm
Albert,
Joe
Subject: Re: 95 Riv hard starting only when hot Fri Apr 15, 2022 11:50 am
redbaron wrote:
Albert,
Joe
In the spirit of the holiday, I tried to think of the "one-time" or rare maintenance stuff I've had to do on my car.
- regasketing from the lower intake manifold out. - brake booster check valve - radiator - front and rear sway bars (broke both after upgrading to Moog Problem Solver end links) - rebuilt HVAC head unit (relamped it twice) - factory exhaust (replaced a replacement with a new factory "onesie") - replace pivot pins in tilt wheel mechanism - drivers and passenger door latches - drivers and passenger door window motors - thermal breaker for power seats (until I figured out why it kept fusing) - water barriers (behind the door cards) in both doors - power antenna (twice) - cam sensor (just for maintenance, it didn't fail) - crank sensor (this was **so** difficult to figure out the first time. Twice. ) - drivers' side window switch cluster - fuel pump (which if you keep at least 1/4 tank of fuel at all times, will probably run forever. Less than that they overheat and die) - passenger side rear ashtray (remember those? The door spring on one failed. Never figured out why.) - drivers side sunvisor (broke the end using it as a sunglass holder. Replaced it. It is still a sunglass holder I just don't horse it) - exterior door latch handles, once each side
The seat hides are outstanding if you keep them cleaned and conditioned. Almost 25 years, no rips, no busted seams, no cracks. (Some character creases over the years ha ha)
redbaron Amateur
Subject: Re: 95 Riv hard starting only when hot Wed May 04, 2022 8:07 pm
Albert,
Finally found time to change crank trigger.
Is good now.
Thank you and thank God!
Joe
Subject: Re: 95 Riv hard starting only when hot Fri May 06, 2022 2:59 pm
redbaron wrote:
Albert,
Is good now.
Joe
You're welcome Joe.
The first time my crank sensor failed, I had to tell the service manager at my friendly GM dealer to replace it "customer request." They had tried various things that didn't work - my sensor had gone intermittently bad warm. So they'd fix something they could find, give me back the car, and it would then quit on the road to East Gybyppe or some darn out of the way place. I'd read about the problem and insisted they replace it - my risk, 'customer request.' They replaced it with a Standard (Blue Streak).
I was not as surprised as they were (mostly relieved), and that sensor lasted two years almost to the day. The next time they replaced it they used a Delphi; still running on that one. I remember having the car towed in for that one. They had learned a good bit about the crank sensor failure by then and had found the Standard sensors were not all that great. An issue with the electrical connections on the Hall sensor in the device separating inside the sensor housing after many many heat-cool cycles.
No scan tool, not even the factory Tech II or whatever, will show crank sensor failure on the Riv. This is because of where the sensor signal is reckoned in the startup sequence. If there is no signal, the fuel pump won't turn on b/c the computer thinks the engine is not turning, and the car won't start. If the car is running and the signal drops, the car will usually stall and stop because it looks to the computer like the car's been in a major accident or the operator has turned the key off (as reckoned by crank signal disappearing, which this car uses as a 'heartbeat.'). Specifically, if no crank signal the powertrain computer kills the fuel pump, whether or not the ignition +12v is present. The heck of it is, there *is* an OBDII code for this -- the dirty secret is, that code pretty much never trips because of the powertrain computer's order of operations. My guess is that if that code ever was triggered it'd more likely be a wiring problem, not the sensor per se.
Based in part on my experience with the crank sensor, that service manager and one of his techs came up with a way to use NOID lights to determine if the crank sensor is bad. That was after my first one failed around 2003 I think. Their approach has spread by word of mouth etc. Here is a relatively recent writeup using a version of their approach: https://dannysengineportal.com/crankshaft-camshaft-position-sensors-function-failure-diagnosis/ - it's a quick read.
For me it's pretty simple. No-start and everything else for a start is OK? Crank sensor original and more than 6 years old, or a replacement more than 2 years old? Eh, you might should replace it. At least, it's time to test it with a NOID.
