 Help 1995 Riveria Transmission issue
2 posters
Carolr
Help 1995 Riveria Transmission issue Empty
PostSubject: Help 1995 Riveria Transmission issue   Help 1995 Riveria Transmission issue EmptySun Oct 02, 2022 10:38 am
I have a 1995 Riveria, 3800 Engine, NOT Super Charged.  A couple days ago out of the blue, I put it in drive, the rpms went up, it would barely move, and then it shifted and was fine.  Everytime I would take off from a stop it would do this.  I checked fluid and it was a little dirty but fine.  Then it started acting the same way in reverse.  After looking further, there was a wire that goes from transmission to under the cover where you put oil.  Plugged it back in and the car started idling smoother but when I put it into any gear, nothing happens.  There is no shifting at all.  What could be the main problem?  I don't have a lot of money to put into car repairs.  Any suggestions would be appreciated.
PostSubject: Re: Help 1995 Riveria Transmission issue   Help 1995 Riveria Transmission issue EmptyMon Oct 03, 2022 12:22 am
How many miles are on it?
» 1995 riviera Front Driver Side Transmission Mount
» 95 Riveria needs turbocharger
» 96 with transmission/electronic issue
» NEW ISSUE HELP
» Temp guage issue......1995 Riv 3800 series 1 SC
