Name : Riviera Joined : 2021-03-24Post Count : 33 Merit : 0
Subject: Steering wheel restoration Tue Mar 21, 2023 8:59 am
Hi, I want to restore my steering wheel and am looking for a good leather spray paint. Has anyone attempted to do this? Also, how do I find the interior color code? Mine has the red interior, I think they were all the same red, weren’t they? Also, if anyone knows where I can find a refurbished steering wheel in red - any info is hugely appreciated
There's a sticker under the spare tire cover in the trunk that has all your codes on it. Here's how to decode them - Link
It should be possible to match the color your wheel was 25 years ago, but your paint has faded and aged; and the correct color won't match what you have now. Reds are particularly bad about turning pink over time.
Here's a site that listed what GM had for interior colors by year and brand - Link
It's not safe to assume every year used the same red. It's likely your interior has a couple different reds, and they changed the next year.
BuickRivieraGeorgia likes this post
BuickRivieraGeorgia Amateur
Wow thanks for the clarification and also the links! Cheers
I ended up buying a NOS steering wheel in Toreador Red, installed that a few years ago, still real nice. I found it on eBay, for some reason a dealer in Florida had several of them. I think it was about $100 at the time.
You might want to shop around, who knows you might luck up.
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07Post Count : 805 Merit : 8
Is it a problem being that they have an airbag in them or you just don't buy the airbag?
Subject: Re: Steering wheel restoration Mon Mar 27, 2023 3:36 am
As it turns out I no longer have that sticker in the trunk… is there any ither way to find the paint codes?? I found this site: https://rivowners.org/features/Ev_Stats/colortrim/95.html
Says red Rivies only came with “dark ruby red” interior and it has a code 794… not quite sure what to make of that… can anyone confirm? And if so, where would I find the formula for it?
Subject: Re: Steering wheel restoration Mon Mar 27, 2023 3:39 am
I am emailing them right now! Have you used their product?
Subject: Re: Steering wheel restoration Mon Mar 27, 2023 3:42 am
Yeah… if I come across anything for 100$ I probably wont spend money on paint… but I don’t usually get that lucky with parts…
Subject: Re: Steering wheel restoration Mon Mar 27, 2023 3:44 am
Don’t need the airbag, just the wheel and buttons if they’re in good shape… do you have one available? If you can take out the airbag, it’s fine if not I can take one already assembled
95 was 'dark ruby red' - burgundy
97-99 was 'toreador red' - an oxblood or cordovan color
If you don't have a local/regional auto paint shop (around me that would be Elmira Auto Paint, (800) 388-6801) that color-matches and will computer-blend paint to the factory paint code, make you a rattle can of it too) try the number I posted, or maybe contact Eastwood (www.eastwood.com).
carguy8888 Junkie
