 Master Cylinder
3 posters
stangrestorer6473
Master Cylinder Empty
PostSubject: Master Cylinder   Master Cylinder EmptyWed Jul 05, 2023 3:38 pm
Hello,
New here and to the Riviera world...
I am helping the owner of a 1983 Convertible with some issues he has and getting his car back on the road...
I am looking for a master cylinder for the car and have had no luck with local and online vendors finding the correct listing for a replacement unit.
The car is an 83 convertible with a V6 motor... it has  4 wheel disc brakes and the listing for the master are very confusing and sometimes wrong. So I do not feel comfortable in pulling the trigger with an online vendor...
The current set up is a booster with an aluminum body with a plastic reservoir..
The part number from GM was 18030428 and is discontinued.
My research has shown a cast iron unit and I believe that was used with a Hydr boost set up....  most of the others state rear drum brakes..
Any help or direct with this would be greatly appreciated ... Thank you
Merit : 180
PostSubject: Re: Master Cylinder   Master Cylinder EmptyThu Jul 06, 2023 11:48 pm
https://www.jackcartergmpartsdepot.ca/p/Cylinder/51931952/18030428.html
supersession
https://www.jackcartergmpartsdepot.ca/p/Cylinder-Assembly--Brake-Master-Cylinder/119645925/19431511.html
maybe phone them to confirm.
dAriel49
PostSubject: Re: Master Cylinder   Master Cylinder EmptyTue Aug 08, 2023 11:46 pm
Howdy, OP! Where you able to find one?
Master Cylinder
» Write-Up: Brake Master Cylinder - Install & Bench Bleed
» brake fluid leak---master cylinder or booster?
» ABS actively resetting itself while braking (solved:master cylinder seal)
» misfire cylinder 4
» cylinder heads
