 Rough idle vibration in steering wheel and pulsating noise and vibration
5 posters
meechie115
Rough idle vibration in steering wheel and pulsating noise and vibration  Empty
PostSubject: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptySun Sep 17, 2023 5:47 pm
My 97 Riviera sc is idling rough the steering wheel is shaking and I here a pulsating noise . I've already done full tune up and both trans mounts . Could it be an exhaust thing? What do you guys think ? I'm putting a motor mount and two new belts in a few days I only run 93 gas and it only has 73,000 MI it sat for two years . I did oil and supercharger oil and air filter plus other small maintenance.
Merit : 149
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyMon Sep 18, 2023 6:31 pm
Any Check Engine Light?
Merit : 180
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyMon Sep 18, 2023 10:58 pm
What dos "full tune up" mean?
meechie115
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyTue Sep 19, 2023 2:58 am
Spark plugs , wires , coil packs , air filter, oil . Haven't done injectors yet but that's not usually included. Spark plugs iridium ac Delco gapped at .60 , blue ngk wires , msd coil packs ( the 5
D576 are sold out everywhere) I have the original coil packs and they are still good by the way . I'll probably get some wires with bigger mm and less resistance probably 8.5 mm msd . But none those should be problem.
carguy8888
carguy8888
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyTue Sep 19, 2023 11:44 am
Did you use Delco mounts, especially the one in the rear? If you use cheap aftermarket ones they are going to vibrate. I know from personal experience.
meechie115
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyWed Sep 20, 2023 7:58 am
Wasn't cheap I don't use anything cheap. I did go store brand on the mounts though duralast . I don't think that's it but obviously idk
carguy8888
carguy8888
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyWed Sep 20, 2023 9:02 am
That was my problem. The rubber is much harder and translates the vibration through the car.
meechie115
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyWed Sep 20, 2023 9:17 am
You remember what brand
carguy8888
carguy8888
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyWed Sep 20, 2023 9:18 am
West Star or something, got it on RockAuto. As soon as I change to an ACDelco mount it went away. That's why the aftermarket ones are $20 and the AC Delco is like 80
meechie115
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyWed Sep 20, 2023 9:50 am
Oh no never go to cheap especially on unknown brands from rock auto . Mine are from AutoZone.... now I'm trying figure out if my clutch is bad or I need flush cus my trans ain't acting right. I'm changing the fluid the filter and gaskets this weekend. Hopefully that'll do it if not I'm changing solenoids and doing a flush . If that don't work the whole thing gets replaced.this what happens when cars sit they fall apart. Still 73000 miles though so imma keep investing
carguy8888
carguy8888
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyWed Sep 20, 2023 9:51 am
Good luck on your quest.
Merit : 180
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyThu Sep 21, 2023 8:14 pm
Check that the primary resistances match each other coil to coil on the ones you pulled - and the secondaries as well.  If they match each other then put the old coils back on. A used D576 is better than a new pretty much anything,inm experience. Two of mine are original to the car and the third was a junkyard coil I got when the new coil I put on to replace one that a bad wire killed off, caused a slight lope.  That's about 410,000 miles of service.
As for wires, the Delco wires for the SC Riv are fine.
You should check the spec on that sparkplug gap.
Merit : 180
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyThu Sep 21, 2023 8:15 pm
What do you mean by the transmission isn't acting right?
meechie115
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyMon Sep 25, 2023 9:55 am
The D576 are nice they are hard to find I still have and my consider but the msd are just as good or the next best thing so should never be a noticeable difference. I can tell you don't understand what the car needs to perform well because you ask me to check but that's the manufactured gap . The old school if it ain't broke don't fix it works but it's narrow. These parts are fine . The wires could be better but they're not bad . I'll see what happens after my last motor mount is changed and belts replaced. My trans fluid needed flush and I did that and replaced filter with gasket also cleaned my solenoid. Should be fine now I didn't receive check engine light but trans was showing different faults but none consistent and from the look of the filter and fluid I say it's good now.
Ship
Ship
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyMon Sep 25, 2023 12:19 pm
I had a '97 Riviera once. Vibration was up through the steering wheel. Replaced the tranny mounts with replacement Delco's and vibration was gone. Also, remember that the '97 suspension was a one-year-only type. So, you might look into engine mounts too.
Merit : 180
PostSubject: Re: Rough idle vibration in steering wheel and pulsating noise and vibration    Rough idle vibration in steering wheel and pulsating noise and vibration  EmptyThu Sep 28, 2023 10:01 pm
I guess you'll just work on ti until you're done.
» Strange intermittent vibration/chatter/noise behind dash
» need steering wheel, please help!
» FAQ: High Mile Club - Wear/Repair Reports
» Steering Wheel
» FAQ: Power Steering Pump & Hoses - Noise & Problems
