 Loud grinding like noise when sharp turning at tand still or slowly moving
4 posters
meechie115
Loud grinding like noise when sharp turning at tand still or slowly moving  Empty
PostSubject: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptyTue Oct 03, 2023 7:47 pm
My 97 Riviera makes rough noises when turning sharp or all the was . From the inside sides like a grinding noise but Im not sure but it makes me cringe and there's no noise when I jack it up and turn . Is it rack and pinion? I filled up my fluid it's probably over filled but could it be bad fluid from sitting two years ? It's only when I turn out of parking spaces or tighter turns especially when I'm not moving or moving slow and turning .
carguy8888
carguy8888
PostSubject: Re: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptySun Oct 08, 2023 6:24 am
It could be a lot of things but I would check the subframe bushings. Your front frame or cradle as it's called could be moving.
meechie115
PostSubject: Re: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptySun Oct 08, 2023 3:19 pm
Basically My whole front end needs replaced the struts the tire rods and maybe my cv joints . Oh and control arm bushings.
carguy8888
carguy8888
PostSubject: Re: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptySun Oct 08, 2023 5:47 pm
They are certainly contenders.
Merit : 104
PostSubject: Re: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptyMon Oct 09, 2023 6:53 am
First things first...
Unless the power-steering fluid looks and smells pristine, jack up the front of the car and put a pan under the return line to the pump.  Use a pair of Vice-Grips to hold the end of the return line in the pan.  Fill the reservoir to the top, cap it, and start the engine & slowly turn the wheel side to side until you run out of fluid.  If the results look or smell dirty, do it again & then re-attach the return hose & fill it per instructions...  The final fill can be "de-bubbled" by slowly turning the wheel back & forth with the engine off, again, per the shop manual.
Finally, these systems are INSANELY sensitive to fluid level...  In my own (1997) experience, GM's removing the vent-hole from the cap causes a lot of problems by causing the system to "pull a vacuum" if the fluid is not perfectly filled.  After changing 2 steering pumps in a row - because the first one was crap - I had to overfill the reservoir until I was done working the wheel lock-to-lock with the engine OFF, and then gently doing the same thing with the engine & pump running...  It was, to say the least, a PITA - but I've had 6 months with NO groans, moans or assist problems.
meechie115 likes this post
meechie115
PostSubject: Re: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptyMon Oct 09, 2023 7:46 pm
I do need to do that I just been noticing other problems I looked under the car and I seen that I have a lot of work to do in the front end but that needs to be done as well I added more fluid but I need to empty the power steering fluid and change it all
KenBluder
KenBluder
PostSubject: Re: Loud grinding like noise when sharp turning at tand still or slowly moving    Loud grinding like noise when sharp turning at tand still or slowly moving  EmptyWed Nov 01, 2023 8:27 pm
A bad strut bearing is another possibility. I have one going and the sound you describe is similar to what I am hearing.
» Grinding noise, but good brake pads
» Help, strange noise when turning right.
» Grinding noise and Knocking
» Grinding noise from engine bay? (Series I)
» Grinding Noise From Back Tire?
