| Aftermarket stereo install, but how do you make the HVAC dim properly? | |
ADDvanced Member
Name : ADDvanced Joined : 2024-03-18 Post Count : 56 Merit : 4
| Subject: Aftermarket stereo install, but how do you make the HVAC dim properly? Tue Mar 26, 2024 6:01 pm | |
| From what I understand, the factory stereo is a link between the HVAC and the rest of the dash, so if you install an aftermarket deck, the HVAC just stays on full brightness. Is there a diagram that shows how to fix this issue? | |
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Tue Mar 26, 2024 6:11 pm | |
| If it's not in the FSM, good luck. AlbertJ was the last of the knowledgeable people still on this board. I'm not at that level. | |
ADDvanced Member
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed Mar 27, 2024 8:09 pm | |
| Update: I'm not sure if it's because I have a 95 which is a bit different than the 96-99s, but the HVAC buttons dim with the rest of the dash, even with an aftermarket stereo installed. | |
ADDvanced Member
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed May 01, 2024 5:11 pm | |
| Update: The actual LCD display DOES NOT dim, I haven't figured out how to solve that. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed May 01, 2024 5:29 pm | |
| The dimming is tied in with the ambient light sensor in the middle of the dash between the defroster grills. When the sensor goes bad, it is dim all the time because the car thinks it is night, all the time. Pretty sure the sensor is not available. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
ADDvanced Member
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed May 01, 2024 5:40 pm | |
| No, it's bright all the time. I turn on the lights and all the buttons and the LCDs on the whole interior adjust with brightness. The exception is hte LCD on the HVAC module, it stays 100% bright the whole time. | |
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed May 01, 2024 5:49 pm | |
| My experience with my 98 was that the wiring occasionally goes bad. The wire actually corrodes from inside, and you can't see it from the outside. I had that happen to me a number of times during my ownership. The cam sensor trouble code, the power mirrors, and the anti lock brake harness. The HVAC module is also a well known problem with these cars. I had mine redone by a guy on Ebay. Very difficult to say what your problem is. Might be a connection problem, might be the HVAC module. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed May 01, 2024 10:33 pm | |
| - ADDvanced wrote:
- From what I understand, the factory stereo is a link between the HVAC and the rest of the dash, so if you install an aftermarket deck, the HVAC just stays on full brightness. Is there a diagram that shows how to fix this issue?
get the FSM and check the pinouts for the connectors so you can fix this if indeed it is an issue. | |
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Wed May 01, 2024 10:35 pm | |
| - ADDvanced wrote:
- No, it's bright all the time. I turn on the lights and all the buttons and the LCDs on the whole interior adjust with brightness. The exception is hte LCD on the HVAC module, it stays 100% bright the whole time.
The LED indicators in the HVAC buttons do stay bright all the time. | |
ADDvanced Member
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Thu May 02, 2024 12:54 pm | |
| Not the indicators, the LCD panel. The part that displays the numbers. | |
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Sat May 04, 2024 2:56 am | |
| - ADDvanced wrote:
- Not the indicators, the LCD panel. The part that displays the numbers.
That's a vacuum fluorescent display. This isn't a problem i've seen. I'd start with what Larry stated, since he's seen this problem before. Albertj PS - did you get a FSM set? | |
ADDvanced Member
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? Sat May 04, 2024 6:30 pm | |
| Yeah I have a full FSM, was using it to diagnose the random gremlins a month ago | |
| Subject: Re: Aftermarket stereo install, but how do you make the HVAC dim properly? | |
