| No heat | |
Dan B Amateur
Name : Dan B Joined : 2022-01-12 Post Count : 27 Merit : 0
| Subject: No heat Mon Apr 15, 2024 6:55 am | |
| Not getting any heat out of my 98 riv.. it was fine until I drained the radiator & reservoir refilled with 50/50 dexcool did I do something wrong? | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-24 Post Count : 2186 Merit : 149
| Subject: Re: No heat Mon Apr 15, 2024 7:46 am | |
| - Dan B wrote:
- Not getting any heat out of my 98 riv.. it was fine until I drained the radiator & reservoir refilled with 50/50 dexcool did I do something wrong?
Radiator level is probably low. Wait until cool, then remove the cap and check. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
Dan B Amateur
| Subject: Re: No heat Tue Apr 16, 2024 1:47 pm | |
Name : Location : Finger Lakes of New York State Joined : 2007-06-01 Post Count : 8606 Merit : 180
| Subject: Re: No heat Wed Apr 17, 2024 1:05 am | |
| fairly common problem and the aftermarket actuators sold via Amazon are fine actually. Just look for them using the GM part number(s) on the sticker on your actuator. OR you can also just get the gear - there's a couple people who 3D print the things and also see https://www.amazon.com/Blend-Door-Actuator-Gear-Rebuild/dp/B01BKW3AKI/ref=sr_1_1_sspa.
Most likely installing one of those $13.- gears will 100% fix your problem once-and-done. | |
Dan B Amateur
| Subject: Re: No heat Thu Apr 18, 2024 12:54 am | |
Dan B Amateur
| Subject: Re: No heat Mon Apr 22, 2024 9:56 am | |
| Well crap all 5 actuators are cracked like that what the hell?? | |
Dan B Amateur
| Subject: Re: No heat Mon Apr 22, 2024 9:58 am | |
| Subject: Re: No heat Mon Apr 22, 2024 10:52 am | |
| - Dan B wrote:
- Well crap all 5 actuators are cracked like that what the hell??
...dont overthink it, just replace the gears. used to be able to get the older actuators with metal gears from junkyard(out of 80s GM pickup trucks for instance) and swap the old gears into the newer actuators. not anymore really Albertj | |
Dan B Amateur
| Subject: Re: No heat Mon Apr 22, 2024 11:10 am | |
| Not really over thinking just curious as to why they all broke.. it's a m.f.'er to reach 1 of them on the driver's side got the whole dash ripped out oh boy | |
| Subject: Re: No heat Wed Apr 24, 2024 11:31 am | |
| The plasticizers gas out over time, making the part brittle. The hole in the factory gear is a bit smaller than the metal cylinder it's pressed on to, that's what holds the gear in place when it's new, and what causes the gear to split when it's old. | |
| Subject: Re: No heat | |
| No heat | |
