| | Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 | |
+10nvsteve albertj EatDirtFartDust jeffyd123 Redline johnd89 Jason AA cragmor 95_River 14 posters | |
95_River Amateur
Name : Brandon Location : Columbia, SC Joined : 2007-01-23 Post Count : 32 Merit : 0
| Subject: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sun Jan 28, 2007 7:54 pm | |
| Click for write-up: https://rivperformance.editboard.com/t144p30-write-up-build-your-own-aldl-obdi-scan-tool-for-95#158080____ Hello guys, it seems to be some confusion about the 95 year/model Riviera and what scanning tool/cable to use to read OBD I codes. GM used a OBD II connector to interface a OBD I system. An OBD II cable/software will not work on the systems. (I tried) Use this link for for more information. http://aldlcable.com/sc/details.asp?item=aldlobd2 You can purchace a cable or they give instructions to build one yourself using a standard PC serial cable. They also have several links to free scanning software and utilities. | |
| | | cragmor Amateur
Name : Jerry Location : Iowa Joined : 2007-02-12 Post Count : 49 Merit : 0
| Subject: 95 OBD homemade cable Tue Feb 13, 2007 3:20 pm | |
| I would LOVE to be able to run some software on my laptop, and capture data while driving. This would help with things like my current problem of the car stalling while driving. My scanner will capture something like 3 seconds. Hard to time that with the random stalls. Anyhow, I have a 95 Rivi, the good ole' OBD-I with the OBD-II connector. I cannot find any resource that says that THIS is how you would make a USB or RS-232 cable to connect to a PC and run with whatever software. Can anyone point me to such a resource, or if you have one, tell me where you got it, got the plans etc? Thanks. | |
| | | 95_River Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Thu Feb 15, 2007 6:39 pm | |
| I have one. Go here: http://www.aldlcable.com/sc/details.asp?item=aldlobd2
Also, download EFILive here:
http://store.efilive.com/download.aspx#downloads3
They don't have definitions for our car but I found that the Pontiac vin 1 and vin K works somewhat well. It will clear codes and give you much info. I dont think the boost meter works because when I tap the gas lightly, it says boost goes to 100%. Check it out, it works pretty good for me. | |
| | | AA Administrator
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Thu Feb 15, 2007 9:13 pm | |
| Boost is either 100% or 0%. It just tells you if you're in vacuum or boost. To calculate boost, you subtract baro pressure from MAP. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | 95_River Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Feb 21, 2007 10:00 pm | |
| That makes more since. The bad thing about that program is that is dosent feature a KR reading. I wonder if some calculation with some other key values would render a valid KR value. If not, I need to see if I can locate another definition file that will register KR. Damn OBD 1. | |
| | | AA Administrator
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Feb 21, 2007 10:43 pm | |
| Nothing can "calculate" KR. It is created as a response to knock, which is picked up via mics on the engine block. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | cragmor Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Tue Mar 13, 2007 5:51 pm | |
| I purchased the cable listed above. I installed EFlive on my laptop, and selected the 95 pontiac vin1 sig. I cannot get anything to work from there. IS there something I need to do yet? IO try to run it but I get errors in the window. | |
| | | 95_River Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Mar 21, 2007 3:10 am | |
| Sorry for the late reply Crag, its boat season so I've turned my attention to tha Bayliner....anyway, So you are using the above def file, and you have the cable firmly plugged into the car and the serial port on the laptop? Make sure you select the "Engine data and DTCs" Macro, NOT the Clear trouble codes macro, and click the green stop sign looking icon at the top. It should have a pop up thats says start ALDI (F3). If you get an error of:Com timeout: Expecting frame header byte then you do not have communication with your ECM. We may need to take it a step further. Try this and if that dosent work, I'll give yo my Email and phone #. 'll try to walk you through it. | |
| | | cragmor Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Mar 21, 2007 11:25 am | |
| I am wondering if there might be a problem with the USB adapter I am using. I use it all the time to interface with telephony equipment over RS-232 connections. I saw no reason it would not work for this. Perhaps tonight, or tomorrow I will give it a try, and I will post any errors I am getting. | |
| | | cragmor Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Mar 21, 2007 3:56 pm | |
| Here is what I am getting. 55:39.462: Opening COM6 8228,8,N,1 55:50.436: Start macro: Engine data and DTCs: DATADTC 55:48.563: Error: Reply frame checksum failure 55:48.573: Error: No echo received from MAX232 55:48.581: Send: $F4,$57,$01,$00,$B4 55:48.803: Com timeout: Data frame truncated: - Code:
$C8,$AE,$95,$30,$E8,$77,$FE,$C9,$2E,$10,$F4,$9C,$FD,$90,$5C,$2F,$08,$94,$91,$5B,$B0,$E9,$D0,$AD,$F1,$D1,$5B,$A0,$E1,$C8,$AE,$95,$30,$E8,$77,$FE,$C9,$2E,$10,$F4,$9C,$FD,$90, $54,$2F,$08,$94,$91,$5B,$B0,$E9,$F8,$5B,$3D,$FC,$C8,$AE,$95,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 55:49.102: Com timeout: Data frame truncated: $C8,$AE,$95,$30,$E8,$77,$FE,$C9,$2E,$10,$F4,$9C,$FD,$90,$5C,$2F,$08,$94,$91,$5B,$B0,$E9,$C8,$AE,$95,$30,$E8,$77,$FE,$C9,$2E,$10,$F4,$9C,$FD,$90,$5C,$2F,$08,$94,$91,$5B,$B0, $E9,$D4,$2E,$0C,$08,$54,$CB,$FF,$D5,$0D,$07,$C4,$FF,$C8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 55:49.115: Send: $F4,$57,$01,$00,$B4 55:49.326: Com timeout: Data frame truncated: $9C,$A3,$57,$01,$00,$B4,$90,$5C,$2F,$08,$94,$C8,$AE,$95,$30,$E8,$77,$FE,$C9,$2E,$10,$F4,$9C,$FF,$90,$5C,$2F,$08,$94,$91,$5B,$B0,$E9,$C8,$AE,$95,$30,$E8,$77,$FE,$C9,$2E,$10, $F4,$9C,$FD,$90,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 55:49.348: Error: No echo received from MAX232 55:49.376: Error: Reply frame checksum failure 55:49.544: Error: Reply frame checksum failure 55:49.579: Error: No echo received from MAX232 55:49.635: Send: $F4,$57,$01,$00,$B4 55:49.647: Error: Reply frame checksum failure 55:49.671: Error: No echo received from MAX232 55:49.692: Error: Reply frame checksum failure 55:49.718: Stop macro: Engine data and DTCs: DATADTC | |
| | | 95_River Amateur
| Subject: Battery Dead Wed Mar 21, 2007 10:49 pm | |
| Sorry man, I havent driven the Riv in 3 weeks and the battery is dead. I was going to get a screen shot to compair with you. I'll try again after a good overnight charge. Can you not bypass the USB adapter and run straight serial? I have the comm port setting set at default. | |
| | | cragmor Amateur
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Tue Mar 27, 2007 10:47 am | |
| Well, it turns out that the problem is my USB adapter. I connected directly to a PC that is in my garage, and I was able to collect fine. I will have to try another adapter. Aparently, IOGear will not work. | |
| | | Jason Aficionado
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Mon Mar 03, 2008 5:28 pm | |
| For the obd1 guys If you want to make your own cable (not too hard if you have skills with a soldering iron) try http://www.akmcables.com/techinfo.htm ; and http://winaldl.joby.se/aldlcable.htm
If you are building your cable using an rs-232 (serial) cable and plan on using an adapter, I've found that FTDI chip adapters work the best. For some reason, the "keyspan" adapter touted by the DHP board seems to be garbage.
If you are short on time, you can buy a premade USB cable from pcm performance for around 50$. No adapter required.
As for tuning programs, there are several. Tuner C.A.T.S. is Ok, and you can try it for free for 30 days. http://www.tunercat.com/tnr_desc/do_tc.html | |
| | | johnd89 Rookie
| Subject: interface cable Fri Mar 14, 2008 12:00 am | |
| Hi,
The connector on my '95 s/c looks like that:
\ x x x o o x x o / \o x o x x o x o/
where: x = empty; o = connector Would this cable work for me too even if the connector looks different?
Thanks! | |
| | | Redline Enthusiast
Name : Mike Location : Dallas, TX Joined : 2008-12-29 Post Count : 141 Merit : 0
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Dec 31, 2008 11:24 am | |
| Thats my understanding from reading the other post, but I thought that the OBD1 used a diff connector.... I'll give it a shot this evening and see... Thanks, mike | |
| | | jeffyd123 Enthusiast
Name : Jeff Del Vechio Joined : 2010-03-15 Post Count : 108 Merit : 4
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sun May 30, 2010 10:41 pm | |
| Been messing with EFLive v4 and a homemade cable and its reading data but not giving me any codes. any ideas?
thanks'
Jeff | |
| | | EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27 Post Count : 284 Merit : 2
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Wed Mar 02, 2011 4:12 pm | |
| I have a 95 Buick Riviera naturally aspirated. The check engine light is on and I'm trying to get the DTC's. I bought the $60 ALDL usb cable as linked on the first page, I downloaded EFILIVE, but I cant get the damn DTC's out. It just says no chatter, or no connection found. Here's what I get: Please help. I'm so frustrated with this car. | |
| | | albertj Master
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Thu Mar 03, 2011 12:33 pm | |
| - EatDirtFartDust wrote:
- I have a 95 Buick Riviera naturally aspirated. The check engine light is on and I'm trying to get the DTC's. I bought the $60 ALDL usb cable as linked on the first page, I downloaded EFILIVE, but I cant get the damn DTC's out. It just says no chatter, or no connection found.
Here's what I get:
Please help. I'm so frustrated with this car. BUMP EFILive as far as I can tell does not claim to support the '95 RIv (or much of anything GM before '98 for that matter) -- see http://www.efilive.com/index.php?option=com_content&view=article&id=147&Itemid=146 for the list. I kinda wonder how Shawn got it to work. Do you think it would be possible for you to PM to Shawn? might get you attention quicker. | |
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Thu Mar 03, 2011 1:15 pm | |
| | | nvsteve Member
Name : Steve Location : Minden NV Joined : 2011-10-06 Post Count : 53 Merit : 3
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Fri Jul 20, 2012 7:21 pm | |
| So I bought the ALDL cable with the usb connection, installed the drivers on my Windows7 laptop, installed the Tunerpro RT software and the definition files for the car, figured out the com port connection mystery, when I plug it to the car with key on, it says its connected, but not ready and no hardware detected. I can't figure out how to get the software running! Very frustrating!!
I have a SES light on and want to read the code!!!!! | |
| | | nvsteve Member
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sun Jul 22, 2012 4:01 pm | |
| I have not had any success getting the Tunerpro RT software to work on my '95 SC. A member of the tunerpro forums has suggested that as a last resort, pulling out the fuse for the engine control module and then putting it back in as a possible fix to make the ECM communicate with Tunerpro.
First of all after looking at the owner's manual I can't tell which fuse controls the computer. Can someone tell me which fuse it is?
Secondly, would like some opinions on whether this is even a good idea? Possible problems if I pull the fuse? I know I will lose whatever codes are stored.
Last question has anyone had success with any other scan software that would work with the OBDI/OBDII cable? I tried Freescan but it doesn't want to work either.
Thanks! Steve | |
| | | nvsteve Member
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sat Jul 28, 2012 5:31 pm | |
| Ok last time I'll ask ........
Has ANYONE had success using ANY scanning software product with a ALDL usb interface cable on a '95 S/C Riviera?
If so what product and how did you do it?
I've tried Tunerpro/RT, Freescan, and EFILive. No luck with any of them.
If I can't get it to work soon I'll have to have the mechanic try his tools.
Soooooo very frustrated! | |
| | | AA Administrator
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sat Jul 28, 2012 6:34 pm | |
| Hey '95 owners, can someone advise Steve on this? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | nvsteve Member
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sat Sep 01, 2012 6:29 pm | |
| Update.......
My mechanic used his scanner to read my code. He had trouble getting it to work, said he needed a "key slot" or something like that to get his reader to work, whatever the heck that is.
Anyway I wonder has anyone heard of that, and if so what does it mean and does that help to solve the mystery of why I can't get the software to work?
By the way the code was P1406, EGR position sensor, which I'm told is no big deal to drive as is.
Steve | |
| | | AA Administrator
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 Sat Sep 01, 2012 9:30 pm | |
| | | Sponsored content
| Subject: Re: Write-Up: Build Your Own (ALDL) OBDI Scan Tool for '95 | |
Similar topics | |
