| Fuel Injector Cleaning | |
+20denim L67GAMSE93 Abaddon albertj robotennis61 Karma SuperRiv07 98riv Rickw Jason 99Rivman dreww rivcop Brad95Riv palermocorey90 AA NO 4 EVR Jack the R Mr.Riviera Sag 24 posters |
Sag Enthusiast
Name : Martin Age : 42 Location : St- calixte Qc Joined : 2007-10-26 Post Count : 166 Merit : 0
| Subject: Fuel Injector Cleaning Thu Nov 01, 2007 10:42 am | |
| That's wat i've found in my injector while cleaning'em one at a time by hand in brake cleaner(don't fear they do it in garage before reinstall) You can't belive how it rev nice now. note:i've used injector cleaner less than a month ago!!! | |
| Subject: Re: Fuel Injector Cleaning Thu Nov 01, 2007 6:24 pm | |
| nice! injector cleaner doesnt work, and you just proved that yet again. i die a little inside everytime someone pays $9 for an 8oz bottle of "SUPER OCTANE 110" or "+ 5mpg inj. cleaner". yea adding 8oz will really increase 20gals of 93 up to 110 octane. but seriously though try running some sea foam in the vac line now. thats is something that actualy does work at cleaning up carbon in the upper intake. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Fuel Injector Cleaning Thu Nov 01, 2007 8:58 pm | |
| - Sag wrote:
- That's wat i've found in my injector while cleaning'em one at a time
by hand in brake cleaner(don't fear they do it in garage before reinstall) Use rubber gloves at least - cancer ain't fun and games. | |
Sag Enthusiast
| Subject: Re: Fuel Injector Cleaning Fri Nov 02, 2007 10:47 am | |
| Seafoam been done recently trust me this engine is almost new now a stock serie one can kik some ass oh yeah | |
NO 4 EVR Addict
| Subject: Re: Fuel Injector Cleaning Sat Nov 03, 2007 4:46 am | |
| How difficult of a job is removing the injectors? | |
| Subject: Re: Fuel Injector Cleaning Sat Nov 03, 2007 11:49 am | |
| It's not too bad. You need to disconnect the fuel lines, then five nuts holding the rail on. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Sag Enthusiast
| Subject: Re: Fuel Injector Cleaning Tue Nov 06, 2007 1:16 pm | |
| And pull hard to remove injectors from rails don't fear(but don't forget to remove clip before). | |
palermocorey90 Expert
| Subject: Re: Fuel Injector Cleaning Wed Nov 28, 2007 7:39 pm | |
| 1 think i will add, is before u putt the injectors is to spray around them with WD-40 or PB blaster to lube the o rings u dont want to tear one of them and be for you install them lube them very well. i lubed mine like 5 or 6 times before installing and they went in like well i wont say it cuz its perverted | |
Brad95Riv Member
Name : Brad Age : 44 Location : Wisconsin Joined : 2007-01-18 Post Count : 97 Merit : 0
| Subject: Re: Fuel Injector Cleaning Wed Nov 28, 2007 8:04 pm | |
| On an engine this old, I'd probably just replace the o-rings when reinstalling the injectors. | |
rivcop Amateur
Name : Kevin Age : 45 Location : Cincinnati, Ohio Joined : 2007-10-27 Post Count : 22 Merit : 0
| Subject: Subject: Why clean your injector by hand Wed Nov 28, 2007 8:38 pm | |
| So, after removing them do you let them soak? And then scrub them? | |
dreww Junkie
| Subject: Re: Fuel Injector Cleaning Thu Nov 29, 2007 12:43 am | |
| - Brad95Riv wrote:
- On an engine this old, I'd probably just replace the o-rings when reinstalling the injectors.
yea, $40 or something like that from the dealer. i got some sitting in my garage for when I do my injector upgrade. | |
99Rivman Aficionado
| Subject: Re: Fuel Injector Cleaning Fri Mar 07, 2008 7:01 pm | |
| I'm getting ready to do this and this question was never answered?? - rivcop wrote:
- So, after removing them do you let them soak? And then scrub them?
I figure as bad as Silver Arrow #10 was maintained they probably used the cheapest gas they could get too, and even with good gas with 180,000 miles on it I'm sure the injectors are a mess. I've already done the seafoam in all three places so I figured this would be a good time to clean the injectors? | |
99Rivman Aficionado
| Subject: Re: Fuel Injector Cleaning Fri Mar 07, 2008 7:06 pm | |
| - dreww wrote:
yea, $40 or something like that from the dealer. i got some sitting in my garage for when I do my injector upgrade. I have to ask, $40 for just the "O" rings? I just got Fel-Pro "O" rings from Advance for $3 for a package of four, $9 plus tax?!? | |
Jason Aficionado
| Subject: Re: Fuel Injector Cleaning Fri Mar 07, 2008 7:12 pm | |
| - Quote :
- I just got Fel-Pro "O" rings from Advance for $3 for a package of four, $9 plus tax?
p/n please! | |
99Rivman Aficionado
| Subject: Re: Fuel Injector Cleaning Fri Mar 07, 2008 7:25 pm | |
| - Jason wrote:
- Quote :
p/n please! Fel Pro Fuel Injection O-Ring SetPart Number: ES70599I'm not positive they fit yet, going to do it tomorrow, but that is what they listed for it. | |
| Subject: Re: Fuel Injector Cleaning Sat Oct 18, 2008 6:27 pm | |
| 99Rivman, Did the FelPro O-rings work. I'm going to swap my injectors soon and would like to know if I have to go to the dealer for proper O-Rings or not. Thanks | |
98riv Moderator
| Subject: Re: Fuel Injector Cleaning Sat Oct 18, 2008 7:38 pm | |
| They will work. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: Fuel Injector Cleaning Mon Oct 27, 2008 11:39 pm | |
| Man I Should Probably do this Considereing I have 160k and they have never been cleaned or changed, at least the old lady I bought it form didnt beat on here it was babied to the miliage it has | |
| Subject: Re: Fuel Injector Cleaning Sun Feb 08, 2009 10:07 pm | |
| digging up an old thread, but i am doing this soon and the question asked on page 1 is still unanswered. so i'll ask it again: do you just let them soak and them spray them off with brake cleaner? what do you soak them in?
thanks, Matthew _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Karma Aficionado
| Subject: Re: Fuel Injector Cleaning Mon Feb 09, 2009 11:36 am | |
| I soaked mine in pure injector cleaner. From the first post in this thread I got the impression that they were soaked in brake cleaner.... _________________ | |
| Subject: ASNU Fuel Injector Cleaning Machine Fri Jan 14, 2011 7:52 am | |
| I am toying with the idea of starting my own injector cleaning service. It requires no certification that i know of,and the ASNU machine is automatic and very easy to use. the machine does all this Features & Technical Specifications Test & Service up to 8 injectors at one time LED Backlit Display Window Open Viewing Window for Injector Spray Comparison LCD Digital Operational Display Multi Language Selection Programme Glycerine Filled Pressure Gauge 0 - 10 Bar / 0 - 145 PSI (0.2 increments) Variable Pressure Regulator with "Boost Button" Universal Fuel Rail Accepts all Top Feed Injectors Adapter Blocks for Mono Point & Side Feed Injectors In-Line Flow Tubes for Easy Delivery Comparison "Up & Over" Tube Drain System (Lifetime Guarantee) Membrane Key Pad Operation Wide Range of Dynamic & Static Tests Dynamic Injector Resistance Check Injector "Shot" Counter Display Injector Run-Time Display Duty Cycle Display Run injectors up to 20,000 RPM High Performance Pump Upgrade Option In-Built Ultrasonic Cleaning System Removable Wiring Harness Manual & Automatic Cleaning Cycles Suitable for GDI (Gasoline Direct Injection) Suitable for Injected Motorcycles Suitable for Injected Marine Engines Suitable for LPG Injection For use on EVERY type of injector on the market Multi Voltage Power Input Nylon Coated Casing for Long Life Complete Parts and Accessories Programme Injector Service Tools It might be a good way to make extra cash and knowing many in the auto world would be to my advantage. what yall think?? | |
Karma Aficionado
| Subject: Re: Fuel Injector Cleaning Fri Jan 14, 2011 8:15 am | |
| How much will it cost you to get something like that? _________________ | |
| Subject: Re: Fuel Injector Cleaning Fri Jan 14, 2011 8:30 am | |
| I'm not sure. So far i haven't been able to locate a price online.Ill call the distributor as soon as the hour rolls around.They are also available used. This is an area many shops don't get involved in? i cant understand why? could it be that chasing "other" problems is more rewarding? Beats the hell outa me.. | |
Karma Aficionado
| Subject: Re: Fuel Injector Cleaning Fri Jan 14, 2011 8:48 am | |
| My guess is because many online places can get great coverage by shipping the injectors around. Take that mrinjector.us site you referenced in other threads. Injectors are so small, it wouldn't be a problem for me to ship them mine from Canada. And the overall amount of work they do on each injector is great for only 16$ each. _________________ | |
| Subject: Re: Fuel Injector Cleaning Fri Jan 14, 2011 8:53 am | |
| very true. regarding mrinjector,he gave me an 1 extra of everything and on the o-rings a couple more. And $5 bucks from where i am is good. But I bet i could turn a profit servicing them. There are classes to take to teach you everything you need to know,but no certification that i can see. | |
| Subject: Re: Fuel Injector Cleaning | |
