| Subject: Re: What is the L67 (Series I)? Fri Feb 10, 2012 4:08 pm | |
| - albertj wrote:
- captain12pk wrote:
- What all did the 3800 series 1 model engine go in.I need a motor.
try contacting moradpartscompany.com, on the Dash on the right, among the list of RivPerformance sponsors. morads specializes in Series 2 and later 3800s, they tend not to take anything with a Series 1. But car-part.com should also be able to help you locate one. | |
hawke23 Special
Name : jack Age : 74 Location : mobile al. Joined : 2012-05-04 Post Count : 1 Merit : 0
| Subject: Re: What is the L67 (Series I)? Fri May 04, 2012 11:21 pm | |
| if you are looking for a series 1 engine, the local wrecking yard right outside mobile al. has one recently pulled from a 95 riviera with trans still attached. i am looking for a trans to fit a 99 gtp and thought that i had found one until i got there and found out that it was a series 1 from a 1995 riviera. the trans is the 4t60E trans and im informed(correctly or not im not sure) that it wont work in the 99 gtp series 11 car. if you would like more info on the series 1 motor and trans.let me know/ | |
