| same problems after intake job | |
palermocorey90 Expert
Name : Corey Age : 34 Location : Rome NY Joined : 2007-10-03 Post Count : 2968 Merit : -24
| Subject: same problems after intake job Sat Dec 01, 2007 3:32 pm | |
| ok i redid my intake gaskets, cleaned out everything new plugs new plug wires,new antifreeze, new oil new vacuum lines, new fuel filter new MAF New TPS, new IAC but i still have the same problem with my car, either it wont start and u need to really crank on it, or you need to rev it up with peddle to the floor , it runns at higher RPMS with tons of gas but with die in the lower RPMs. i made 2 videos for you guys of me trying to get it started one outside and one inside the car
https://www.youtube.com/watch?v=ZvdkFRok8pM the outside video
https://www.youtube.com/watch?v=vi0V_ufT61o interior video | |
| Subject: Re: same problems after intake job Sat Dec 01, 2007 6:04 pm | |
| outside video doesnt work for me. is the IAC installed correctly? is the CEL on and can you read it? double check the vac lines and plugs. sounds like the engine has too much fuel and not enough air and is choking out, but its hard to tell w/out being there. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: same problems after intake job Sat Dec 01, 2007 6:40 pm | |
| i got it workin
i was told that its getting more air then gas, and thats why its dying | |
| Subject: Re: same problems after intake job Sat Dec 01, 2007 8:25 pm | |
BillBoost37 Junkie
| Subject: Re: same problems after intake job Sat Dec 01, 2007 10:37 pm | |
| Have you tried a fuel pressure test?
Is this more or less common if the tank if nearly full vs nearly empty? | |
TType_Riviera Fanatic
| Subject: Re: same problems after intake job Sun Dec 02, 2007 12:48 am | |
| can you verify the map sensor is seeing a 5volt reverence at the connection? | |
| Subject: Re: same problems after intake job Sun Dec 02, 2007 10:58 am | |
| - BillBoost37 wrote:
- Have you tried a fuel pressure test?
Is this more or less common if the tank if nearly full vs nearly empty? no we have no yet, but the tank has about 6 gallons of gas in it - TType_Riviera wrote:
- can you verify the map sensor is seeing a 5volt reverence at the connection?
i dont understand what you meen | |
BillBoost37 Junkie
| Subject: Re: same problems after intake job Sun Dec 02, 2007 1:49 pm | |
| I'd suggest testing fuel pressure. If you don't have enough pressure, you can easily stall.
On the map and 5volt reference, he means that you should check the wires on the connector of the map sensor for +5V, one wire should have 5V with the key to the on position. | |
| Subject: Re: same problems after intake job Sun Dec 02, 2007 8:26 pm | |
| If it's fuel pressure related, why would it run fine with more throttle, and die at low RPM? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: same problems after intake job Sun Dec 02, 2007 8:43 pm | |
| higher the rpms more fuel using. so prob at higher rpms uel pump is able to use the amount of gas it would use normally at lower rpms | |
| Subject: Re: same problems after intake job Sun Dec 02, 2007 11:01 pm | |
| check you 2 bar map sensor tot he corresponding voltage at 0.00 | |
BillBoost37 Junkie
| Subject: Re: same problems after intake job Mon Dec 03, 2007 5:53 am | |
- If it's fuel pressure related, why would it run fine with more throttle, and die at low RPM?
Running fine at higher could be a seemingly better. It can run lean and with the rpm up you would notice it less. Also depending on how much higher and correct me on this one as I'm drawing on Bonnsperience, the second stage for the pump could kick in. B'villes with the L67 have a fuel module that runs the pump at 8volts typically and full voltage when say 3/4-wot. Also a pump that is leaking down may exhibit the symptoms more at idle. (Personal experience.. 23 lbs barely starts and idles horrible. higher rpm seemed better but very lean) | |
| Subject: Re: same problems after intake job | |
