96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
| Subject: EVAP Canister location? Fri Dec 28, 2007 1:30 pm | |
| Can someone tell me where the evap canister is located?
Thanks | |
| Subject: Re: EVAP Canister location? Fri Dec 28, 2007 2:43 pm | |
| If I remember, it's a rectangular box under the driver side, in front of the rear wheel. In the same area as the fuel filter. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
99Rivman Aficionado
| Subject: Re: EVAP Canister location? Fri Dec 28, 2007 4:30 pm | |
- If I remember, it's a rectangular box under the driver side, in front of the rear wheel. In the same area as the fuel filter.
That is right , I just have seen mine on the '99 that is, while I was changing the fuel filter the other day. | |
96RIVMANN Fanatic
| Subject: Re: EVAP Canister location? Fri Dec 28, 2007 7:35 pm | |
| Has anyone on the board had any trouble with there's? I am still trying to hunt down my code p1406 problem and was wondering if this could be contributing to it? | |
| Subject: Re: EVAP Canister location? | |
