| blower knock? | |
+6deekster_caddy Mr.Riviera T Riley AA ewolfe0050 RhinoFLA 10 posters |
RhinoFLA Aficionado
| Subject: blower knock? Fri Jan 11, 2008 8:52 pm | |
| Driving earlier on my way home from work, I started hearing a squeaking noise and I wasn't sure of where it was coming from, so I stopped and popped my hood. I didn't find the source of the squeaking there, but I did notice a sound almost like a slight knocking now and then, like something was rattling around or like an old bearing or something and it souded like it was coming from the blower but it was hard to tell.. I put my hand on it and could feel the vibration whenever it made the sound but then again, it could be from anywhere.. any ideas? are there any known problems like this that stem from the blower? | |
ewolfe0050 Aficionado
| Subject: Re: blower knock? Sat Jan 12, 2008 12:43 am | |
| coupler bearing. Mine went out recently on the old M90. Sounded like a rattling can when the car was cold. Got quiet when it warmed up. It's an inexpensive part 25-30 and easy to change. I didn't have to worry about replacement when I switched over to the GV. | |
| Subject: Re: blower knock? Sat Jan 12, 2008 12:45 am | |
| Not a bearing. Just called a sc coupler... | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Jan 12, 2008 1:25 am | |
| yeah that's about what it sounds like.. thanks eric | |
| Subject: Re: blower knock? Sat Jan 12, 2008 10:18 am | |
| I don't know if I'd call it an easy job, but it can be done in a few hours. You must remove the alterator and SC snout. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Jan 12, 2008 11:09 am | |
| if i drive it like that for like 2 weeks longer could it damage anything? going to wait until I throw an mps on it since the belt will already be off | |
| Subject: Re: blower knock? Sat Jan 12, 2008 11:54 am | |
| I drove with mine like that for 2 years (about 50-60k miles). The coupler was only slightly worn, still in good shape. After changing it, there's still some noise, just not as much. With an air intake added, it's normal to hear the "grinding marbles" sound on start-up because the BBV is opened when the engine is cold. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: blower knock? Sat Jan 12, 2008 12:04 pm | |
- I drove with mine like that for 2 years (about 50-60k miles). The coupler was only slightly worn, still in good shape. After changing it, there's still some noise, just not as much. With an air intake added, it's normal to hear the "grinding marbles" sound on start-up because the BBV is opened when the engine is cold.
did you notice an increase on boost figures??? with the installation of supercharger couplers?? | |
| Subject: Re: blower knock? Sat Jan 12, 2008 1:56 pm | |
| No. In my case, there was no reason to change it other than the noise. And for the difference it made, I don't know if it was worth the effort. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: blower knock? Sat Jan 12, 2008 3:49 pm | |
| Ryan, you can double check that it is the coupler by removing the belt and rocking the pulley back. feel for any slack in the rotors. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Jan 12, 2008 4:36 pm | |
| thanks matt, what is the size and shape to look for for the tensioner pulley bolt? would a serpentine belt tool work on it? i've never even looekd at it | |
| Subject: Re: blower knock? Sat Jan 12, 2008 4:58 pm | |
| 15mm socket and torque it away from you (reverse thread bolt) to loosen the tesnion and slip off the belt. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: blower knock? Sat Jan 12, 2008 5:03 pm | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Jan 12, 2008 5:16 pm | |
Buickman104 Enthusiast
Age : 38 Location : New York City Joined : 2007-11-29 Post Count : 156 Merit : 0
| Subject: Re: blower knock? Sat Jan 12, 2008 5:34 pm | |
- I don't know if I'd call it an easy job, but it can be done in a few hours. You must remove the alterator and SC snout.
I would gladly trade with you! For the series 1 the entire supercharger has to be removed and taken apart. It is all practice. Once you do enough of them then you can do it in under and hour for the m90, and under 2 hours for a series 1 m62. Look at the bright side, it is the only part in the supercharger that actually needs maintenace every 100k miles. | |
palermocorey90 Expert
| Subject: Re: blower knock? Sat Jan 12, 2008 8:36 pm | |
| well when you do replace it hears a link
http://www3.sympatico.ca/aepa/blowerinstall.html | |
dreww Junkie
| Subject: Re: blower knock? Mon Jan 14, 2008 6:41 am | |
| - palermocorey90 wrote:
- well when you do replace it hears a link
http://www3.sympatico.ca/aepa/blowerinstall.html using that link, it took me a couple hours max working by myself and never having done anything like it. didnt even have the right tools or a garage. definitely an easier fix on this car. And good excuse to change out your SC oil. | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Mon Jan 14, 2008 5:31 pm | |
| I think i'm going to end up with more oil on me then I put back in | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Fri Feb 08, 2008 8:24 pm | |
| Just changed my blower oil.. that has to be the worst thing i've ever smelled in my life... anyways, while the hood was popped, I took off the belt and spun th pulley a bit, I was able to move it about half an inch before it seemed to hookup, would that be the play from a broken coupler? | |
| Subject: Re: blower knock? Fri Feb 08, 2008 10:29 pm | |
| wow 1/2" of play would be the most i've ever heard of for a worn coupler. i'm betting that is where all of the sound is coming from. if you want a hand changing it, let me know _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Feb 09, 2008 4:54 pm | |
| would that broken coupler be affecting performance? | |
| Subject: Re: blower knock? Sat Feb 09, 2008 6:25 pm | |
| not really, it may cause boost to radically fluctuate coming off throttle, but during acceleration the coupler is still doing its job unless it has completely broken apart (never heard of it) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Feb 09, 2008 6:51 pm | |
| at wot I do notice t hat it'll flicker in between 6 and 7 a little | |
| Subject: Re: blower knock? Sat Feb 09, 2008 11:25 pm | |
| They tend to wear and then rattle, instead of actually breaking. It's only about $30 for a new and improved couple from ZZP. Might want to consider changing it since you're working on the SC anyway. | |
RhinoFLA Aficionado
| Subject: Re: blower knock? Sat Feb 09, 2008 11:43 pm | |
| Right right, i'll have to save that project for when I have some time on the weekend | |
| Subject: Re: blower knock? | |
| blower knock? | |
