| Subject: OEM Roller Rockers in Series I? Fri Feb 22, 2008 1:09 am | |
| Wikipedia says:
"HP was rated at 205 for 1991-1993 engines (models vary), and 225 for 1994-1995 engines. The additional horsepower was gained by using a larger throttle body, roller rockers and epoxy coated supercharger rotors, improving efficiency."
Is this true? If not, how should it read? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: OEM Roller Rockers in Series I? Fri Feb 22, 2008 7:52 am | |
| I don't know but what wikipedia page are you reading? 3800? | |
oldsman105 Junkie
| Subject: Re: OEM Roller Rockers in Series I? Fri Feb 22, 2008 10:58 am | |
| The rockers are roller pivot. Not roller tip.
I will try to find some pictures | |
oldsman105 Junkie
| Subject: Re: OEM Roller Rockers in Series I? Fri Feb 22, 2008 12:51 pm | |
| Thanks Oldsman. So is it correct to call them roller rockers? I think that's a bit misleading. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
oldsman105 Junkie
| Subject: Re: OEM Roller Rockers in Series I? Fri Feb 22, 2008 5:03 pm | |
| The tip has no roller so I would say roller rockers is not the correct name for it. | |
| Subject: Re: OEM Roller Rockers in Series I? | |
