brmcm15 Member
Name : Brandon Age : 33 Location : Macomb, Michigan Joined : 2008-12-02 Post Count : 84 Merit : 0
| Subject: help with slidey thing. lol Wed Nov 18, 2009 11:32 am | |
| alright i didnt kno what i was called but i found it in a diagram, the red arrow is pointing at it: and was wondering on how to get it off? do i have to remove the whole center console? | |
| Subject: Re: help with slidey thing. lol Wed Nov 18, 2009 1:47 pm | |
| IIRC you have to remove that whole big piece it's attached to - shown seperate from the center console in the diagram. Emm, yeah - here's a pic of mine when I had it out - Take off the console lid, undo the screws in the storage compartment, and carefully pry it up from the back. I think the front is only held down with clips. Oh, and pull the shift knob first. There's a u shaped clip on the front of it, about halfway down. Remove that clip and the knob will slide off the shaft. | |
brmcm15 Member
| Subject: Re: help with slidey thing. lol Wed Nov 18, 2009 1:58 pm | |
| cool. thanks jack.
is there any way of separating it from the big piece?
cause my plan was to paint it. | |
| Subject: Re: help with slidey thing. lol Wed Nov 18, 2009 2:11 pm | |
| I painted the edges of mine. You don't want to take the cover off. Mask off the parts you don't want to paint instead.
If you're going to install a dash kit, just paint the edges so your overlay has a clean area to stick to. | |
99Rivman Aficionado
| Subject: Re: help with slidey thing. lol Wed Nov 18, 2009 4:59 pm | |
| - brmcm15 wrote:
- is there any way of separating it from the big piece?
The cup holder is molded into the rest of the trim panel; the cover is attached with clips and a spring. I'm not sure how hard it would be to remove but I'm sure it wouldn't be real easy. You can see one of the clpis and the spring in the picture below: | |
brmcm15 Member
| Subject: Re: help with slidey thing. lol Thu Nov 19, 2009 12:48 am | |
| ok thanks. yea i really dont want to mess with a spring and get it all messed up lol. so i think ill just do the safe thing and use some painters tape and save some time.. here's a pic of what i have so far done | |
| Subject: Re: help with slidey thing. lol | |
