| Plug condition | |
| Subject: Plug condition Sat Apr 12, 2008 3:09 pm | |
| An autolite 104 after a few thousand unmodded miles. You guys see any problems? | |
| Subject: Re: Plug condition Sat Apr 12, 2008 5:26 pm | |
| nope, not at that angle. how does the electrode look? what is your gap set at? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
ibmoses Aficionado
| Subject: Re: Plug condition Sat Apr 12, 2008 6:50 pm | |
| Need more pics, It looks like some dark flecks on the center electrode. If so, that would be an indication of detonation. Bert | |
TonySmooth89 Aficionado
| Subject: Re: Plug condition Sat Apr 12, 2008 11:56 pm | |
| It almost looks like it bent upwards. | |
| Subject: Re: Plug condition Sun Apr 13, 2008 12:02 am | |
| I don't remember what the gap is set at. We discussed it on regalgs.org and I believe I went with Aaron's recommendation, whatever it was. I've never heard any knocking. It runs smooth. | |
| Subject: Re: Plug condition Sun Apr 13, 2008 1:00 am | |
| Looks fine. Perfect plug. Measure the gap and adjust if necessary. Replace, or leave it in for another 10-15k miles. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Plug condition Sun Apr 13, 2008 11:50 am | |
| Would the gap change with use? If not, then it's fine, and we know 104's can be run in stock Riv's with no problem. | |
| Subject: Re: Plug condition Sun Apr 13, 2008 5:09 pm | |
| they will change slightly. (gap gets larger as the electrode burns away) but with only a couple thousand miles they probably haven't even changed. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Plug condition Sun Apr 13, 2008 7:29 pm | |
| looks ok> thats the color a properly functioning plug should be,not too hot,wht, lean condition. not black,running rich. ashen color is good. | |
| Subject: Re: Plug condition Sun Apr 13, 2008 10:20 pm | |
| All-rightey then! FWIW I posted this because Aaron asked a looong time ago. He probably doesn't even remember. But I remembered when I was putting on the free plug wire shields he sent me! So here it is! | |
| Subject: Re: Plug condition Mon Apr 14, 2008 10:08 am | |
| It is good to see an AL104 from a stock engine with no evidence of fouling. Thanks for the update. From this we can conclude it's okay to skip the 605s, especially if you are a spirited driver. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Plug condition Mon Apr 14, 2008 10:04 pm | |
| Well I'm not driving with much spirit due to gas prices, that's for sure. | |
| Subject: Re: Plug condition Tue Apr 15, 2008 10:12 am | |
| Report back in 15k miles, Jack. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Plug condition Tue Apr 15, 2008 2:19 pm | |
| At the rate I'm putting miles on another 15k will come after the Maya-predicted end of the world in 2012. | |
| Subject: Re: Plug condition | |
| Plug condition | |
