| | FAQ: Automatic Leveling Control (ALC) Concerns | |
+6799Rivman 1967 - 1997 Riviera gunmetalRED c0reyl dboydakid Lisa P charlieRobinson gmann3001 BigRay1125 Mattwa Coltrain billy1290 AKC GreenMonster J. Chris Davis Derek sqrivi Mike9874 Karma epic612 Robb soulbladexll Snowdog Abaddon BrianEsser ciro307 98inSFl Z-type DEMonte1997 Eldo Allstyle Sweepspear LARRY70GS GMFreak8 Dj Brady ewolfe0050 1995 Riv Ryan from Ohio Rickw No-Lift gliderguy albertj robotennis61 '96reese Jack the R T Riley ibmoses TonySmooth89 ¤DoughBoy¤ 96RIVMANN BillBoost37 1badriv jhodges robertwolf86 TType_Riviera AA 97rivman 1998 Riv dreww clazzicradiorepair bayarearivi 98riv deekster_caddy oldsman105 Mr.Riviera jax95riv NO 4 EVR 71 posters | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Oct 22, 2014 5:14 pm | |
| BTW it's totally normal for the system to self-test after you start the car. It should inflate/deflate the system and it usually happens within a minute of startup. After that self-test it generally won't run unless you put something in the trunk.
For a test you can sit on the back bumper for a minute and it should kick on, then get off and the car should rise up, and then lower. That tells you that the basics are working right. If it keeps turning on beyond that, there could be a small leak somewhere.
The camber issue isn't really related to the shocks. It shouldn't drop enough to affect that, even with a small leak. | |
| | | LARRY70GS Aficionado
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Wed Oct 22, 2014 6:22 pm | |
| If the rear of the car is low, it will have more negative camber than it should. When I first bought my Riviera, the ALC was not working at all, and I was unaware of it. One day, a friend following me in another car commented that it appeared that my tires looked tilted in at the top. Thinking it was an alignment issue, I took it in to a friend's shop. When we discovered there was no camber adjustment at the rear, my friend commented that the back of the car was low. While it was on the alignment rack, we physically lifted up on the rear of the car, and you could see the camber change in a positive direction. I subsequently went through the diagnostic in the FSM for "Back of Car too low", and eventually discovered a broken wire between the level sensor and the rear fuse/relay block under the rear seat. Every time you start the car, or cycle the ignition switch, the system will self test after a 17-35 second delay. The compressor will run from 3-5 seconds. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | deekster_caddy Master
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Thu Oct 23, 2014 12:41 pm | |
| Great info Larry! Okay, so get the height set properly first. | |
| | | billfrank85 Member
Name : Will Age : 38 Location : Carbondale, IL Joined : 2014-08-03 Post Count : 97 Merit : 0
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sat Nov 15, 2014 11:06 pm | |
| When I turn the key, or start the car, the compressor kicks on after a few seconds and runs for maybe a minute or two. If I park it and shut it off, it runs for another minute or two...maybe even a little more. It never runs just parked. From what it sounds like, that seems like normal operation but is it normal for it to run that long at those times?
As far as "setting the ride height" are you referring to the process that requires a scanner? Sounds like an expensive dealership only fix...ugh. | |
| | | 1997riv Enthusiast
Name : Joined : 2014-11-23 Post Count : 131 Merit : 0
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sun May 03, 2015 12:43 am | |
| | | matt270avian Expert
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sun May 03, 2015 7:59 pm | |
| Just an FYI to anyone who has a non-functional ALC. Check the vacuum lines that go to the 2 modules next to the compressor. There are 3 nuts that hold the bracket holding the compressor/2 units to the car. After that it just kind of slips out and drops down, and at this point you can remove it if you need to or check on these lines. Mine were so rotted they just fell apart in my hands. They weren't even connected because they had just rotted off of the 2 nipples they attached to. | |
| | | 98riv Moderator
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sun May 03, 2015 8:38 pm | |
| - matt270avian wrote:
- Just an FYI to anyone who has a non-functional ALC. Check the vacuum lines that go to the 2 modules next to the compressor. There are 3 nuts that hold the bracket holding the compressor/2 units to the car. After that it just kind of slips out and drops down, and at this point you can remove it if you need to or check on these lines. Mine were so rotted they just fell apart in my hands. They weren't even connected because they had just rotted off of the 2 nipples they attached to.
I had the same problem with mine. No more leaks once I replaced them. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| | | EyeDoc1 Enthusiast
Name : Christen Location : Vancouver, WA Joined : 2016-03-30 Post Count : 125 Merit : 5
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Thu Jan 09, 2020 6:03 pm | |
| Update: My compressor problem is still with me. It runs for a shade under 5 minutes and cuts off. Fine. Has to be either a compressor or a rubber line. The car rides over bumps MUCH better and is rock solid to the bounce test. In the rear. Fronts? Next thing that needs changing.
Anyway, the compressor. Was in the junkyard a couple of days ago and decided to snatch a compressor unit because...why the heck not. $45 bucks. New they went for like $500. Anyway, remove the plastic splash panel (3 Philips screws). Then disconnect a black "pinch" clamp arrangement that disconnects both air lines to the shocks from the compressor. This is rigid thin plastic, similar to what the vacuum lines are under the hood. Next disconnect a large electrical connector mounted to the fender well by removing a little white spike-type retainer, then get a pick, and disconnect by wiggling. Then remove a 10 mm bolt that attaches one of the rigid lines AND the front of a metal plate that reminds me of a skid plate you'd see under a car to protect oil pans. Easy peasy, vertical mount comes off 1-2-3. Next, get on your back, move to the rear of the car right next to the muffler and you'll see 2-10 mm bolts on the back of the skid plate oriented horizontally. They come off easy. Remove the skid plate and you can leave or disconnect another electrical connector. That connector is what powers the compressor. You can leave it on the skid plate if you're taking it from the junkyard or just pry it off with a "V" shaped trim removal tool or a screwdriver. You then disconnect a long, about 14" long rubber vacuum line from a green nipple mounted on the inner fender. Net, remove 3 bolts with attached rubber insulators, and the compressor unit drop down easily. When I dropped the unit, the first things I said was "holy sh*t, these rubber hoses are shot". Yep, original GM 7/32" hose. There are 3 of them. Long one is about 14-15" and mounts to the aforementioned fender well nipple, medium is about 6-7" and the short one is about 5". Both of these mount to the compressor/dryer (maybe that's the correct term--anyway, these have metal, not plastic nipples. All three of these lines connect into a plastic "T" fitting. So home I go, and decided to do mine. Lo and behold, I find my lines are cracked and one of the lines separated to the touch. Figger, why not try and replace the lines first. So my local auto parts store sell 7/32" hose, blister packed, 6' long for less than $4 bucks and is cheaper than hose "by-the-foot". The brand was Prestone, like the antifreeze. Came home, had the car jacked up, skid plate removed, and I was able to change all three hoses without dropping the compressor. TIP: 2 things to do if you're changing hoses. Clean the nipples and squirt some silicone spray on them. 7/32 is a tight, TIGHT fit. No clamps necessary. And put the hoses FIRST on the nipples on the compressor unit and fender well nipple BEFORE you hook it all up the "T" fitting. Much easier manipulating the hoses if you do it in that order. Buttoned it all up and no more compressor noise. If you get a hint of your compressor running too long, change this out before you're relying on some sort of thermal overheating safety switch to stop the compressor. $4 bucks is cheap insurance and the job takes about an hour. Good luck. Oh, while I'm a firm believer thinking that smarter people who get paid 6 figure salaries as engineers designed this for 7/32", I'd not be surprised if 1/4" or 8/32" hose works just as good, would stay in place, and be a darned sight easier to install. But since I already bought it, figured I stick with the 7/32". | |
| | | Sponsored content
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns | |
Similar topics | |
