| What's next? | |
99 Riviera 99 Amateur
| Subject: What's next? Sat Jun 14, 2008 3:25 pm | |
| So I have replaced my interior speakers with the Infinity reference in the front and the rear deck, sounds great...but I know it could sound better.
I have a factory head unit also...what should i replace next??
Thanks
-Cameron | |
| Subject: Re: What's next? Sat Jun 14, 2008 4:45 pm | |
| I would get a 4 channel amp and send some clean, crisp, power to those speakers. You could also get an EQ unit to tweak the sound a little if you want it to sound really good. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Buapo Addict
| Subject: Re: What's next? Sat Jun 14, 2008 5:32 pm | |
| I've done a similar upgrade, and I also know it could sound better...
I've decided to get a 4 channel amp to power the main speakers before I get any type of subwoofer. | |
| Subject: Re: What's next? Sun Jun 15, 2008 2:23 am | |
| Okay,
I want an Infinity amp..but they are 250 for a 4channel...
What's a good amp under 175??
So i can just hook the wires up to the head unit w/ a wiring harness??
It can't be too hard because the battery is under the seat...
When i go to the speakers do i have to solder??
I'm new to this kind of stuff. | |
IBx1 Expert
| Subject: Re: What's next? Sun Jun 15, 2008 8:32 am | |
| $250? Not on Amazon. You can get a refurbished 4 channel, 111 watts RMS amp for about $150 after shipping HERE, or a new 4 channel, 75 watts RMS amp for less than $150 HERE. | |
dreww Junkie
| Subject: Re: What's next? Mon Jun 16, 2008 8:15 am | |
| - 99 Riviera 99 wrote:
- Okay,
I'm new to this kind of stuff. with amps you get what you pay for. but I got a $100 4-ch amp from pepboys running 50wts RMS to my front and rear speakers. Sounds great for a cheap amp and speakers (jenson and audio lightening speakers ) You dont have to solder anything, if you dont want. You can use the crimp on slip connectors. Probably better to solder though, the connectors sometimes slip off. | |
| Subject: Re: What's next? Mon Jun 16, 2008 8:57 am | |
| If you crimp them correctly, then give them a good tug - there's no way those connectors are coming off. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: What's next? Mon Jun 16, 2008 11:48 pm | |
| Wow 100dollars for just the wires for an amp?!!?
I don't think it's worth it. | |
98RIV7777 Fanatic
Name : Anthony Age : 36 Location : Niagara Falls, NY Joined : 2008-06-01 Post Count : 274 Merit : 1
| Subject: Re: What's next? Tue Jun 17, 2008 12:05 am | |
| Check out e-bay and you'll find better deals on all that shit | |
| Subject: Re: What's next? Tue Jun 17, 2008 10:10 pm | |
| I can get a brand new jl audio clean sweep for 175 so im gonna get that versus the ugly head units...good idea? Then i can just hook the amps right in | |
Dj Brady Enthusiast
Name : Brady Age : 49 Location : Wilmore, Ky Joined : 2008-02-04 Post Count : 150 Merit : 0
| Subject: Re: What's next? Wed Jun 18, 2008 10:11 am | |
| Honestly, I think that''s a waste of money. Get yourself an amplifier with speaker level inputs or get a set of line level converters if you want to keep your factory head unit.
http://www.crutchfield.com/S-ownqkUDsYqa/App/Product/Item/Main.aspx?i=142SLC4 | |
| Subject: Re: What's next? | |
| What's next? | |
