| whats this part? | |
+4sburch23 Mr.Riviera manofmany 1wickedninja 8 posters |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
1wickedninja Addict
| Subject: Re: whats this part? Wed Jul 08, 2009 12:52 pm | |
| never mind my bad its a heater hose fitting. anybody know if it just pops out and back in? | |
manofmany Addict
| Subject: Re: whats this part? Wed Jul 08, 2009 12:56 pm | |
| Pretty sure it just pulls off with some force. It might feel stuck on there. Wiggling it up and down firmly while pulling should do the trick. | |
| Subject: Re: whats this part? Wed Jul 08, 2009 1:00 pm | |
| it is hard plastic and a 90* bend so it wont just pop out. i had mine out when i pulled the timing cover. rockauto has that part for a good price, i remember looking it up before. if i recall, you have to take the tensioner bracket off to pull that piece. it is just press fitted in there with 2 O-rings. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: whats this part? Wed Jul 08, 2009 1:04 pm | |
| http://www.rockauto.com/catalog/x,carcode,1022038,parttype,14166
$2.18 gotta love rockauto.
you might be able to get it out without removing anything, but i doubt it since it is held in by 2 non moving parts IIRC. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
1wickedninja Addict
| Subject: Re: whats this part? Wed Jul 08, 2009 1:18 pm | |
| got it out but cant get it back in lol! | |
sburch23 Addict
| Subject: Re: whats this part? Wed Jul 08, 2009 4:59 pm | |
| When I replaced pulleys and belts I had these replaced as well. They were very brittle. I have over 232,000 miles on mine so they had seen a lot of heat but I would recommend everyone check theirs out. A failure, even partial like Josh's could lead to a fried engine. | |
| Subject: Re: whats this part? Wed Jul 08, 2009 6:08 pm | |
| - 1wickedninja wrote:
- got it out but cant get it back in lol!
I should think that you have to unbolt the alternator bracket/coolant-passage that it attaches to, then push it into the motor and push the bracket onto it. | |
| Subject: Re: whats this part? Wed Jul 08, 2009 7:56 pm | |
| They have O-rings on them. Spray with WD40 to assist with the install... and turn and wiggle gently while pushing. | |
| Subject: Re: whats this part? Thu Jul 09, 2009 12:24 am | |
| - deekster_caddy wrote:
- They have O-rings on them. Spray with WD40 to assist with the install... and turn and wiggle gently while pushing.
Do NOT spray them with any kind of solvent! Coating them with straight anti-freeze will give them plenty of lubrication... | |
1wickedninja Addict
| yeah thats what im gonna do. i just didn't have enough time had 2 go 2 work so i drove my monte carlo 2 work. gonna loosen up the alternator/tensioner bracket 2 get back in. | |
BillBoost37 Junkie
| Subject: Re: whats this part? Thu Jul 09, 2009 8:11 am | |
| That is the upper coolant elbow.
Before putting a new one in, clean the holes well to remove any bumps or issues that might keep the o-ring from sealing. You can use nearly any fluid as lubrication for the rings. Just ensure you use something. I usually like vasoline and have yet to have an issue using anything else.
Easiest way to replace it is to remove the alternator and it's bracket. When doing this, be careful. 97-98 had a metal lower elbow as part of the tensioner/bracket. Replace the o-ring on that and lubricate. If it's newer, you'll use the other elbow in the package. The Dorman part number that most parts stores sell for under $4 is 47065. If they don't stock it, they can usually get it the same day. | |
| Subject: Re: whats this part? Thu Jul 09, 2009 8:20 am | |
Coating them with straight anti-freeze will give them plenty of lubrication... WD40 is not a solvent, it's a lubricant??? I always spray o-rings with WD40, fuel injector O-rings, coolant elbows, tight radiator hoses... helps with assembly. Antifreeze would be a fine lubricant as well for this situation. | |
1wickedninja Addict
| Subject: Re: whats this part? Thu Jul 09, 2009 1:12 pm | |
| ot it change wasn't as hard as it looked lol. just a pita | |
curious riv Addict
Name : Chris Age : 44 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: whats this part? Thu Jul 09, 2009 4:27 pm | |
| i used RTV sealant for lube when I worked on mine. lol. | |
| Subject: Re: whats this part? Thu Jul 09, 2009 5:09 pm | |
| - curious riv wrote:
- i used RTV sealant for lube when I worked on mine. lol.
oooh boy. That's a big mistake. GL next time you have to remove it. | |
| Subject: Re: whats this part? Thu Jul 09, 2009 6:46 pm | |
WD40 is not a solvent, it's a lubricant??? I always spray o-rings with WD40, fuel injector O-rings, coolant elbows, tight radiator hoses... helps with assembly. Antifreeze would be a fine lubricant as well for this situation. Per their website: WD-40 is the ultimate multi-purpose problem solver. WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant.There's a lot more stuff in their secret formula than just lubricant... Even it it was just oil, you don't really want to put any oil in the cooling system anyway. More importantly, because these o-rings are designed for this 'water-based' environment, the material they're made out of may well be damaged by any oils/solvents. On a recommendation, I once put soluble oil in 3 cars to lube the water pumps and inhibit corrosion. In a matter of weeks, all 3 cars had blown large chunks out of their radiator hoses... As we agree, straight anti-freeze is a good assembly lube for cooling system hoses, etc. . | |
| Subject: Re: whats this part? | |
