| Engine Losing Power | |
+24J. Chris Davis bigdave LARRY70GS th3fr4nchi5e charlieRobinson rivparadise Pipes ewolfe0050 DEMonte1997 robotennis61 flyineagle96 Crashtestdummy crazyjackcsa AZANC1995 manofmany turtleman albertj deekster_caddy ibmoses Chicken RhinoFLA Mr.Riviera AA mdhall1 28 posters |
mdhall1 Member
Name : Matt Age : 45 Location : New Braunfels, Texas Joined : 2008-06-15 Post Count : 58 Merit : 1
| Subject: Loss of power??? Tue Jul 01, 2008 10:30 pm | |
| Need some help, My 95 Riviera is acting like it has a rev limiter at 3500 RPM’s. When I rev it up it hits 3500 and pop’s and sputters, will not rev past (Park, or Neutral). When I put it in drive and hold my foot on the brake Idle drops to 800 RPM’s and jerks like it wants to stall. When driving there is no power, when I hit the gas there is no “get up and go”. Here is what I have done over the last 500 miles;
Fuel pump, Fuel filter, TPS sensor, MAF sensor, Plugs, wires, PCV, starter, alternator. I just had a local shop do a full rebuild on the transmission. I would love some input. I unfortunately do not have a scan tool, and there is no SES????? Thanks Matt | |
| Subject: Re: Engine Losing Power Tue Jul 01, 2008 11:17 pm | |
| How many miles on the car? Here's a long shot...
From GM shop manual:
"Poor Acceleration at Low Speed
If the (TC) stator is freewheeling at all times, the car tends to have poor acceleration from a standstill. At speeds above 30-35 mph, the car may act normally. For poor acceleration, you should first determine that the exhaust system is not blocked, and the transmission is in 1st gear when starting out.
If the engine freely accelerates to higher RPM in Neutral, you can assume that the engine and the exhaust system are normal. Check for poor performance in Drive and Reverse to help determine if the stator is freewheeling at all times." _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Engine Losing Power Wed Jul 02, 2008 1:24 am | |
| i believe there is a rev limiter at ~3500 if the car is in P or N. the popping is somewhat normal if you let off the throttle too quickly. (more noticeable if you have exhaust work done) normal idle when warm is ~650rpm i think the sputtering and poor acceleration could be alot of things, but if the wrong MAF is used, it's broke, or dirty then that would have the symptoms you describe. i would double check the wires, plugs, and MAF. then check for vac leaks. was it doing this before you had the rebuild/repairs? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Engine Losing Power Sun Jul 13, 2008 7:13 pm | |
| I drove yesterday a total of about 100 miles to work, friends houses, home stuff like that. I was on my way home last night, about 700 feet from my house and my car just loses all power. I managed to pull it into my house, and it was too dark to start anything then. Today I went out to get food and drove it for about 10 minutes, and the same thing happened. I shut the car off for a few minutes, and then drove it home. Any ideas?
No codes, plugs/wires have very low miles on them. | |
Chicken Aficionado
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 7:34 pm | |
| How does the supercharger belt look? | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 7:45 pm | |
| - Chicken wrote:
- How does the supercharger belt look?
It looks fine, less than 15k miles on it. Just to clarify, the loss of power makes the car nearly undrivable, it crawls and won't rev past 2k rpm. | |
ibmoses Aficionado
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 7:46 pm | |
| - RhinoFLA wrote:
It looks fine, less than 15k miles on it. Just to clarify, the loss of power makes the car nearly undrivable, it crawls and won't rev past 2k rpm. Only thing I can think to check is the fuel filter. Bert:tavis: | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 7:50 pm | |
| I can check it, but it has probably less than 2-3k miles on it. | |
ibmoses Aficionado
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 7:52 pm | |
| - RhinoFLA wrote:
- I can check it, but it has probably less than 2-3k miles on it.
Probably not the fuel filter then. Bert:tavis: | |
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 10:08 pm | |
| So it only happens when the engine is hot? Everything's fine before it's warmed up? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Engine Losing Power Sun Jul 13, 2008 11:21 pm | |
| leaking antifreeze under pressure? Smell any maple syrup? | |
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 1:35 pm | |
| Why does the fuel filter only have 2-3 K?
Chicken Aficionado
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 1:41 pm | |
- So it only happens when the engine is hot? Everything's fine before it's warmed up?
Sounds like the tranny is slipping... | |
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 6:24 pm | |
| Well this is not the right way but you could try driving the car in a conveniant area while it has the problem and keep driving it until you get the MIL to pop up and see what the PCM says..
When the problem is a oocuring, does it also idle rough and stuff like that? Does it seem to change while it's happening or is it pretty much totally constant in severity? | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 8:00 pm | |
| It runs perfectly normal until about 10 minutes after driving it. Then it just seems like the timing goes way off because the engine starts rocking really bad, and won't rev past 2k. A couple friends told me to try the cat.. because my cat is stock so it has probably 200k+ miles on it, and a mechanic at a muffler shop about a year ago told me it was, but I didn't believe him at the time. So tomorrow, downpipe and cat delete are getting done, just because it's the easiest and quickest way at the moment. Still open to suggestions. | |
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 9:36 pm | |
| Otherwise it's time to get a scan tool... give us some scans and we'll give you some answers. | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 9:46 pm | |
| - deekster_caddy wrote:
- Otherwise it's time to get a scan tool... give us some scans and we'll give you some answers.
If this doesn't fix the problem tomorrow, i'm going to have it scanned to see what's going on before I go wasting money replacing stuff. | |
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 10:03 pm | |
| Actually, if you have never replaced the crank sensor - that would cause your problem. And it won't set a code. When car cools off it will run but once warm it will quit. Crank sensor wont' show up on a scanner either. It is a $25.00 part that is a real PITA when it fails - basically it is a hall sensor and what happens is it fatigues and starts to fail warm. When it cools off the elements go back into spec. For other postings about it - failure patterns, symptoms, etc. - do a Google searh for GM Crank Sensor, Buick Crank Sensor Problem or similar - you'll find several postings about it. If you can remove the harmonic balancer yourself - I'd just replace the #*&$(# thing, they tend to fail pretty reliably after 130,000 miles or so. Albert j | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 11:00 pm | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Mon Jul 14, 2008 11:07 pm | |
| Any tips on getting to and removing it? | |
| Subject: Re: Engine Losing Power Tue Jul 15, 2008 8:21 am | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Tue Jul 15, 2008 10:45 am | |
| So it's not a common problem on s2 engines? | |
| Subject: Re: Engine Losing Power Tue Jul 15, 2008 11:52 am | |
RhinoFLA Aficionado
| Subject: Re: Engine Losing Power Tue Jul 15, 2008 6:17 pm | |
| I just put in my 3" zzp downpipe, and deleted the cat. I drove it for 10 minutes, and let it idle for another 10, and nothing. Drove it home 10 minutes, and it's fine so far. Hopefully that was the culprit. | |
Chicken Aficionado
| Subject: Re: Engine Losing Power Tue Jul 15, 2008 6:21 pm | |
| that is one of the weirdest things I've ever heard of..... | |
| Subject: Re: Engine Losing Power | |
