 1979 Instrument Cluster Dead, need wiring diagram
2 posters
12voltstuff
1979 Instrument Cluster Dead, need wiring diagram Empty
PostSubject: 1979 Instrument Cluster Dead, need wiring diagram   1979 Instrument Cluster Dead, need wiring diagram EmptyFri Aug 22, 2008 9:12 am
Hello,
I need a wiring diagram for a 1979 Rivi cluster.
Is there an addtional powersupply for the 1979 with a digital dash / cable drive speedo?Thanks for any help. (Alldata manuals stop at 1982)
PostSubject: Re: 1979 Instrument Cluster Dead, need wiring diagram   1979 Instrument Cluster Dead, need wiring diagram EmptySun Aug 24, 2008 5:35 pm
You might check with some of the guys from the Riviera Owners Association.
http://www.rivowners.org/
If you go to the Regional Coordinator page there is contact information for them, Jayson from the DFW area and Ed from the KANSAS CITY area have several of the '79 to '85 Rivieras. If they can't answer your question they might be able to point you in the right direction. There are Technical Advisors that I'm sure could help you but membership in the ROA is required to get that information.
HTH
» non functioning instrument cluster
» 98 Instrument Cluster Repair
» '79 Instrument Cluster. Is there a Separate Power Unit?
» gauge cluster wiring
» Does anyone have a 95' wiring diagram????
