 Coil pack
3 posters
jenkkijussi
Coil pack Empty
PostSubject: Coil pack   Coil pack EmptyFri Oct 24, 2008 2:02 pm
How can I test the coil pack from -95 Riv SC?
curious riv
curious riv
Coil pack Empty
PostSubject: Re: Coil pack   Coil pack EmptyFri Oct 24, 2008 3:44 pm
curious riv
curious riv
Coil pack Empty
PostSubject: Re: Coil pack   Coil pack EmptyFri Oct 24, 2008 3:56 pm
also, there's the old fashion way t check t see if it's firing.
Pull one wire from the plug and put a small screwdriver in there and hold it close to a ground to see if it sparks.. BE CAAREFUL, chances are you'll get a shock too... Hope one of this or the previous post is what you're lookin for... and good luck with it
Merit : 180
Coil pack Empty
PostSubject: Re: Coil pack   Coil pack EmptyFri Oct 24, 2008 5:25 pm
at some auto parts stores you can get a screwdriver for cheap with a neon light inside that will lite if you have good spark. Check at a NAPA or CarQuest that's in the vicinity of car repair shops or vehicle fleets (taxis, buses) and you'll probalby find lots of such tools available.
Coil pack Empty
Coil pack
» Coil Packs???
» coil packs going out? need help fast!
» coil pack info needed
» car trouble - Stalling (coil pack wiring)
» Ignition Coil Pack part # for Supercharged 3800 Series II Engine?
