 Molded carpet
5 posters
manofmany
Molded carpet Empty
PostSubject: Molded carpet   Molded carpet EmptyMon May 02, 2011 2:05 pm
Does anyone know of a reliable place where I could get new carpet? Decided to keep the RIviera and got a Pacifica for the family so I'm trying to fix it up.
Somehow I've worn a hole in the carpet where the heel of my foot goes.
Merit : 180
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyMon May 02, 2011 7:15 pm
You have two choices - to patch the current carpet or get new.
I have purchased carpet (not for the Riv) from Auto Custom Carpets of Anniston, Alabama. If they did not get whacked by the tornados... the carpet I got from them for my Volvo was fine. They supply JCWhitney and others, and also sell direct.
For that matter you may want to try JCWhitney.
As for a patch, what you do is find a junked GM car with same color carpet and cut a section out that's somewhat larger than your holey portion. Basically then you use a knife to trip the edges of the holey section away (get rid of the curl) and cement the new behind, using a hair comb (yeah, a hard-rubber Ace comb works well for this) to pull the nap up so you can't see the cut-in line. If you can get a large enough section of carpet of matching color, best thing to do is cut the replacement section in along the lines where there are major 'valley' bends in the current carpeting. PM me if you have more questions about this.
manofmany
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyTue May 03, 2011 4:16 pm
The entire carpet is in terrible condition so I'll be opting for a new molded carpet.
Unfortunately it doesn't appear ACC carries carpet for the Riviera, which is the problem I'm running into everywhere. I'll check with JC Whitney later this evening.
Merit : 180
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyWed May 04, 2011 6:01 pm
Because the "molds" are blocks and pans of various sizes that are arranged on a stage, you maybe might want to phone them and see if they will make you one. The "stock" carpets are made to order not necessarily inventoried, it's just that they have the patterns.
You also may find someone who will cut-and-sew one for you -- ACC can for instance, they do for the early cars.
Lmck3
Lmck3
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptySun Feb 03, 2019 1:13 pm
the carpet in 1997 riv is looking "tired".
"google" does not lead to a source for a new molded carpet for our 8th gen cars.
nothing resulted from eight clicks including jc whitney, stock interiors, raybucks, ebay...
does anyone know where to get one?
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyMon Feb 04, 2019 1:38 am
Merit : 180
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyTue Feb 05, 2019 10:57 am
Did you *phone* these guys? https://www.accmats.com/about/
Reason to phone: This company is related to the company that invented molded auto carpet. Originally the "molds" that are used to make these carpets were blocks that could be re-arranged on a stage. Given a carpet to copy from, or certain measurements, a replacement can be made by rearranging the blocks, steaming/stamping the carpet, then trimming the edges. They made me a replacement for a Volvo wagon (745) I used to own. It was not in their online catalog either.
Lmck3
Lmck3
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyTue Feb 05, 2019 1:42 pm
did call call custom auto carpet in anniston alabama (256)236-1118.
they cannot supply moulded carpet for 1995-99 riviera
.and.
they do not know who can.
their call center has 6 females answering the phones.
that includes no modder types or hotrodders.
Merit : 180
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyTue Feb 05, 2019 10:44 pm
.and.
**Wow** it's really changed from when I used them for the Volvo carpet.  They had the females answering the phones but the answer was "if we can find one in a salvage yard we can copy that carpet" and such. Worst case was they'd sell you yardage dyed to your color and you could cut-and-sew. The trick with tat is to sew the big seams in areas that are not seen, like under a console
It is entirely possible that Lear made those carpets.
Albetrj
nickwon
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyMon Mar 25, 2019 3:57 am
Check out Newark Auto. They offer replacement carpets for '95 Riviera.
Merit : 180
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyMon Mar 25, 2019 9:04 am
...their current guide (LINK) shows Riviera to '93. Maybe they will cut-and-sew one if you ask.
I bet the Riv floor pan is similar or identical to the other GM late 90's G's and their descendants. To wit:
Wikipedia:
Wikipedia wrote:
The G-body (the GMX690) was based on Cadillac's K-body architecture. The Buick Riviera 2-door coupe moved up from the GM E platform, while the Oldsmobile Aurora 4-door sedan was a new model.
Platform consolidation
Starting with the 1997 Buick Park Avenue, GM consolidated its four large-car platforms; C platform, K platform, H platform, and G platform; all to the G platform. However, GM decided to retain their previous platform designations.[1] These legacy platform designations were used in the VIN number and official GM publications. Models designated as "G" went out of production for MY 1999, but successor models were sold until MY 2011.
Problem is, none of those years G-platform bodies are listed in the Newark guide I found.
That said, a junkyard carpet might not be a bad bet - once out you could clean it, or have it cleaned by anyone offering off-site cleaning of entry mats and area rugs. Problem with having it cleaned is the pricing. Depending on competition in your area it could exceed $100 - for that $$$ you likely could buy a small wet dry vac and large-ish residential steam wand or a ready-made floor steam cleaner to do it yourself. Use the steam wand later to steam clean your engine, smooth draperies, and other stuff.
Lmck3
Lmck3
Molded carpet Empty
PostSubject: Re: Molded carpet   Molded carpet EmptyWed Apr 03, 2019 12:42 am
just called Newark Auto re molded carpet for 1997 riv.
Newark does not have a carpet for the 8th gen rivieras and cannot custom sew one.
they say none exist anywhere and these carpets cannot be had.
also they said they know all the suppliers and nobody has this item.
Molded carpet Empty
Molded carpet
» New Carpet
» FAQ: Wet Carpet - Interior Leak Problems
» Black carpet with tan interior??
» Website for Interior carpet?
» nasty stain on the carpet
