| Write-Up: Yellowed Corner Lenses | |
+57IFallsRon h20man joshuadalegrimes Sir Psycho Sexy llamalor2112 matt270avian charlieRobinson ALR37115 HeartBeatRivi c0reyl Jelorian gmann3001 96riv BMD jlaw ghpcnm IBx1 nebstewart07 bigdave GMFreak8 Steve98 robotennis61 steve s 1wickedninja #1BearsFan woggy dnyce200 DEMonte1997 Eldo Rickw ibmoses albertj Sweepspear sburch23 curious riv deekster_caddy KillaKeninaRiv TonySmooth89 Shintsu manofmany nothincame2mind palermocorey90 Jack the R jimmyriv Buapo SpaceBar 97Riv-Jon turtleman Rivgirl06 Mr.Riviera 99Rivman Andysdorm jax95riv 1998 Riv AA xxsupergman25xx T Riley 61 posters |
| Subject: Re: Write-Up: Yellowed Corner Lenses Tue Jun 16, 2009 4:29 pm | |
curious riv Addict
Name : Chris Age : 44 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: Write-Up: Yellowed Corner Lenses Tue Jun 16, 2009 4:52 pm | |
| its a dark green... i am going to see if i can photoshop it first. If it looks decent, I'll giv it a shot. I'll eventually buy some new ones...buuut, till then? | |
DEMonte1997 Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Tue Jun 16, 2009 5:02 pm | |
| Of all the cornering lenses I've tinted thus far, none of them were yellowed on the inside. Just a LOT of hazing and discoloration on the outside surface that is taken out easily with wetsanding at 2000 grit and polishing with a reputable polish (doesn't even need to be plastic polish). | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Jun 20, 2009 1:47 pm | |
| Here we go, the ultimate Riviera cornering lens solution (for now) - Brand new lenses, reskinned with Crystal View on the outside, and the inside of the front lip. I couldn't get to the part of the lens inside the housing, so there is potential room for improvement. We'll see how they hold up as the years go by. Hopefully very well because in 3 years it'll cost $500 to get these the way the price keeps going up. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Jun 20, 2009 2:44 pm | |
| Where did you get them and how much? | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Jun 20, 2009 9:21 pm | |
| Monster Parts Online, $100. I was surprised to get them at that price. GM Parts Direct wanted $160. | |
KillaKeninaRiv Addict
Name : Kenneth Age : 41 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jun 24, 2009 4:51 pm | |
| is that price just the corner lenses? | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jun 24, 2009 4:57 pm | |
| Yes, for the pair. Lt and Rt. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jun 24, 2009 5:04 pm | |
| not bad. for your headlights, did you clean them or were they never fogged? | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jun 24, 2009 8:50 pm | |
| Never fogged. The headlights were made of good stuff! Better than what I've seen Mercedes-Benz use. | |
Shintsu Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jun 29, 2009 8:23 pm | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jun 29, 2009 10:06 pm | |
| big difference! yours looked more oxidized than yellow, but it worked just the same. interested in how long the clear protection lasts. _________________ 1996 with 254k miles, L32Â 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Shintsu Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jun 29, 2009 10:32 pm | |
| It's supposed to be lifetime as long as it's properly applied. If you look along the top side of the passenger side headlight it's somewhat hazy there before - afterwards it's clear. Amazing how a relatively minor thing can improve the looks of a car quite a bit. Clean and clear headlights just like it was a new car. I'm not sure how much the clarity of the lights are improved but it looks nicer when I look at it. I now look at my headlights the same way I stare at the clean shiny chrome wheels. Definately worth the $28 I paid (It was on sale for around $25 when I bought it) for it. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 1:24 am | |
| Hmm, sounds a lot like Crystal View... | |
dnyce200 Amateur
Name : dnyce Location : baltimore Joined : 2009-07-15 Post Count : 31 Merit : 0
| Subject: Cleaning Headlights,,,,any advice???? Wed Jul 22, 2009 10:23 am | |
| hey everyone dnyce on here again does anyone kno how to clean these yellow headlights??? I've heard of using sandpaper??? but i just got the car and i wanna be careful about cleaning it. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 10:27 am | |
dnyce200 Amateur
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 10:41 am | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 11:32 am | |
| You can also go to www.shop3m.com and purchase on-line for 24.99. Use coupon code "SHOP3M" for free shipping. If it is not available at AutoZone or you don't have an AutoZone near you.
woggy Enthusiast
Name : Paul Age : 62 Location : Altoona, Florida (Somewhere in the ocala national forest) Joined : 2009-04-28 Post Count : 201 Merit : 7
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 11:39 am | |
| I used a kit from turtle wax called headlight lens restorer. available at auto parts stores, this kit has worked very well for me. It has 3 different sanding restoration pads that you use with water and when finished with the 3 steps of sanding you then polish the lenses with the lens compound. i think it was about 12 bucks. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 11:43 am | |
| That sounds like the same procedure as the 3M product only less expensive. BTW, the free shipping code has expired on the 3M site. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 11:49 am | |
| I would like to find one of these kits that include as a final step, some kind of clear-coat that is UV rated to help prevent the lenses from yellowing again. Has any one seen such a thing that is less expensive than the replacement cost of the cornering lense. | |
#1BearsFan Enthusiast
Name : Bill Location : North Carolina Joined : 2008-07-28 Post Count : 231 Merit : 4
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 12:23 pm | |
| I am going to give the 3m kit a try, and I am going to do my tail light lens as well, the backup lights are yellow as hell so the red is too I am sure, even though you cant really tell. | |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 12:41 pm | |
| my corners, and backup lights r yellow as well. might pick me up some of the 3m stuff this weekend. | |
Shintsu Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 3:11 pm | |
| Don't know about that 3M stuff - it looks more like that garbage they advertise on TV that doesn't ever work. My results were done with CrystalView and again would recommend them over anything else. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Jul 22, 2009 3:21 pm | |
| - #1BearsFan wrote:
- I am going to give the 3m kit a try, and I am going to do my tail light lens as well, the backup lights are yellow as hell so the red is too I am sure, even though you cant really tell.
I believe you'll find the red gets much brighter. I'm going to do mine one day - perhaps do the sequential turn signals at the same time. But it's not high priority. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses | |
