Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28Post Count : 437 Merit : 0
Subject: will intense or zzp's cat back fit? Sun Jan 11, 2009 1:12 am
I am really desperately hoping that I can find some sort of cat-back kit for my car, I am not a man of 100% custom exhaust (all raw parts). mainly lookin for a system that is a direct bolt on
Subject: Re: will intense or zzp's cat back fit? Sun Jan 11, 2009 9:08 am
AFAIK there is no cat-back made for our cars. An exhaust shop should easily be able to make a custom cat back for you, to your specs, for a couple hundred. It's a real simple design, striaight back the middle to a Y to the mufflers... Shop around a bit if you don't like the first price you find.
Intense and ZZP sell cat-backs for W-bodys, i.e. GP, Regal, Impala. Not G-bodys.
97rivsc Fanatic
Subject: Re: will intense or zzp's cat back fit? Sun Jan 11, 2009 1:43 pm
ok so I contacted an exhaust and repair shop and I was wondering should I go with the resonator or without, I don't want to have it, but will I need it to avoid being pulled over cuz I love loud and nasty exhaust
Subject: Re: will intense or zzp's cat back fit? Sun Jan 11, 2009 4:42 pm
You should be okay without the resonator. Personally I hate the sound it makes without, but it doesn't get that much louder.
palermocorey90 Expert
Name : Corey Age : 33 Location : Rome NY Joined : 2007-10-03Post Count : 2968 Merit : -24
Subject: Re: will intense or zzp's cat back fit? Sun Jan 11, 2009 5:06 pm
i hope this will help out.ur prolly wont sound just like this but heads the DL
SSAC headers magnaflow 3" high flow cat no resi 3" custom mandrel bent cat back borla proXS 3" in/out 3" tip (this is also with a S1X cam)
BTW its not to bad,the drone aint bad to me. but its loud ass fcuk when u get on it
Buapo Addict
Name : Ben Age : 38 Location : Eastlake, OH Joined : 2007-07-17Post Count : 691 Merit : 2
Subject: Re: will intense or zzp's cat back fit? Sun Jan 11, 2009 6:11 pm
I'd get a glasspack or some kind of resonator. Just my opinion, though.
What's beautiful about the Riviera exhaust is that the dual exits allow you to have it free flowing AND quiet. On my Regal, I had a custom cat back fabbed up, and used a glasspack - and it was still loud, but that was because of the muffler I used.
Jason Aficionado
Name : Jason Age : 40 Location : Comox, BC, Canada Joined : 2007-01-23Post Count : 1378 Merit : 65
Subject: Re: will intense or zzp's cat back fit? Tue Jan 13, 2009 11:49 pm
the corsa #14150 is pretty much a bolt on. It would require very little tweaking to fit. It will set you back over a grand though. Money that would be better spent elsewhere from a performance point of view.
W-body exhausts won't even come close to fitting. Don't waste your time or money.
TonySmooth89 Aficionado
Name : Anthony Age : 35 Location : Florida Joined : 2007-11-14Post Count : 2410 Merit : 16
Subject: Re: will intense or zzp's cat back fit? Tue Jan 13, 2009 11:56 pm
Why don't you like custom exhausts?
Rick's Riv Rookie
Name : Rick Age : 58 Location : auto tech.. Joined : 2008-10-23Post Count : 17 Merit : 0
Subject: Re: will intense or zzp's cat back fit? Wed Jan 14, 2009 1:38 pm
Hey guys... I think Borla ... makes a cat. back for a STS...... Same platform .... should fit
Rick's Riv Rookie
Subject: Re: will intense or zzp's cat back fit? Wed Jan 14, 2009 2:10 pm
Subject: Re: will intense or zzp's cat back fit? Wed Jan 14, 2009 6:14 pm
just have a custom built like mine
97rivsc Fanatic
Subject: Re: will intense or zzp's cat back fit? Thu Jan 15, 2009 12:07 am
how is yours built corey, I want to custom build but want someone to weld for me.
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8604 Merit : 180
Subject: Re: will intense or zzp's cat back fit? Thu Jan 15, 2009 3:11 pm
Jason - first and foremost - congrats on your upcoming marriage.
Second - do you know anyone who's used the Corsa 14150? When I looked it up on line I could not tell what's included.
It looks like one would have to trim a little from the bottom of the rear bumper with a Dremel - but I am not at all sure.
Also - I wonder if others offer a Corsa-like resonator/muffler set that a local shop could weld together, or if the Corsa cans ara available for local fabrication.
Last thing - an editorial comment - markup on mufflers and such is *unbelievable* - we end up paying multiples of what those things cost. Albertj
Subject: Re: will intense or zzp's cat back fit? Thu Jan 15, 2009 5:11 pm
if its above 10* tomorrow i will snatch up a video of it for you
Jason Aficionado
Subject: Re: will intense or zzp's cat back fit? Thu Jan 15, 2009 5:55 pm
-thanks -no. I was going to buy a used one online, but it went over $600 US, so I didn't. The main advantage would be to use the mandrel bent "Y" and main pipe. It's surprisingly hard to find a T or Y pipe that fits. I didn't, even after looking through several catalogs. So I used mandrel bends and made a single 3" pipe.
97rivsc Fanatic
Subject: Re: will intense or zzp's cat back fit? Thu Jan 15, 2009 6:30 pm
ok thanks lots corey
Subject: Re: will intense or zzp's cat back fit? Fri Jan 16, 2009 11:23 am
ok i made a video its 10.8* outside and i now hate you for making me go out in the cold. its an ok video. it should show you everything that you need to know. BTW this is 3" exhaust tubing,
Last edited by palermocorey90 on Fri Jan 16, 2009 11:38 am; edited 1 time in total
T Riley Guru
Name : Travis Age : 34 Location : Minnesconsin Joined : 2007-02-08Post Count : 5127 Merit : 10
Subject: Re: will intense or zzp's cat back fit? Fri Jan 16, 2009 11:30 am
im uploading now, will post video when its all done
it will idle at like 1500rpms on a cold start up.. should sound good
Subject: Re: will intense or zzp's cat back fit? Fri Jan 16, 2009 11:39 am
idle is about 1100
Subject: Re: will intense or zzp's cat back fit? Sat Jan 17, 2009 10:31 pm
did teh video work for you
97rivsc Fanatic
Subject: Re: will intense or zzp's cat back fit? Sun Jan 18, 2009 1:34 pm
vid isnt workin corey, sorry about the coldness lol
Subject: Re: will intense or zzp's cat back fit? Sun Jan 18, 2009 2:57 pm
the video works for everybody else you might need to update ur flash player
97rivsc Fanatic
Subject: Re: will intense or zzp's cat back fit? Mon Jan 19, 2009 1:22 am
ok i got it now, ya doesnt look too difficult but i think im gonna wait until i get my headers in.
Subject: Re: will intense or zzp's cat back fit? Mon Jan 19, 2009 12:03 pm
