| FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune | |
+17Karma nothincame2mind Rickw AA Fuzzy mr riviera texasfan010 ewolfe0050 99prixgt TonySmooth89 1998 Riv T Riley deekster_caddy MintRiv98 turtleman 97rivsc EASHER 21 posters |
EASHER Member
Name : ERIK M. ASHER Age : 55 Location : BLOUNTSTOWN, FL Joined : 2008-10-24 Post Count : 85 Merit : 0
| Subject: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sat Dec 27, 2008 11:47 am | |
| I installed an INTENSE PCM on FRI. and love it!!!! It took less than an hour and started right up with no problems and didn't require a CASE LEARN since no codes were kicked by the new pcm. I noticed a big difference in acceleration especially at top-end. The trans shifts were more positive as well. 60-100mph is very quick compared to the stock computer. I need to give much thanks to rickw for selling me his INTENSE PCM. He is the man!!! I hope to be able to get a HP TUNERS programming suite some time. But until then, this is a low cost solution that works great. | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sat Dec 27, 2008 12:39 pm | |
| what did i tell ya eric? told you that you would definitely not regret it, btw are the trac or abs lights on at all? | |
EASHER Member
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sat Dec 27, 2008 1:32 pm | |
| - 97rivsc wrote:
- what did i tell ya eric? told you that you would definitely not regret it, btw are the trac or abs lights on at all?
Yes you did and I agree 110% with you. As for the ABS and TRAC CNTRL lights, they have been on ever since I got the car. I just put tape over them so they are not a distraction. | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sun Dec 28, 2008 7:28 pm | |
| Erik, when you get that hp tuner, let me know - I'd like to get that bin from you. | |
MintRiv98 Rookie
Name : Patrick Age : 37 Location : EGV illinois Biatch Joined : 2009-01-26 Post Count : 15 Merit : 0
| Subject: FAQ: ZZP or INTENSE Powertrain Control Module (PCM) Tune Fri Feb 06, 2009 1:06 pm | |
| hey guys, Just wondering what would be better worth my money a zzp pcm or a intense racing pcm. The one from zzp seems like you get more for your money, but it seems like people are happier with the Intense racing one, gimmie some opinons | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Feb 06, 2009 1:12 pm | |
| I loved my Intense Racing PCM. It was an excellent starting point. Does ZZP list one for the Riv? | |
EASHER Member
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Feb 06, 2009 3:28 pm | |
| I love my INTENSE PCM!!!!!!!! | |
T Riley Guru
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Feb 06, 2009 3:29 pm | |
| CUSTOM...... find someone from CLUBGP.com in your area.. pay them like 40 bucks... its better too | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Feb 06, 2009 4:05 pm | |
| - 98riviera98 wrote:
- CUSTOM...... find someone from CLUBGP.com in your area.. pay them like 40 bucks... its better too
... as long as they know what they're doing... | |
T Riley Guru
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Feb 06, 2009 4:30 pm | |
... as long as they know what they're doing... most that are willing do.......... | |
TonySmooth89 Aficionado
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sat Feb 07, 2009 2:05 am | |
... as long as they know what they're doing... most that are willing do.......... Not all.... I had a bad experience with a guy near me...as have others with this guy. Lets just say my car ran better before he tuned it... | |
99prixgt Member
Name : Erik Age : 37 Location : NJ Joined : 2009-01-27 Post Count : 90 Merit : 2
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sat Feb 07, 2009 11:14 pm | |
| if you like your motor get an INTENSE pcm. Way to many bad stories with zzp's | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sat Feb 07, 2009 11:28 pm | |
| I've used Intenses for a day and I liked it. Never tried ZZP's | |
MintRiv98 Rookie
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sun Feb 08, 2009 3:04 am | |
| hmm im gunna definatly look into getting a INTESE pcm then | |
ewolfe0050 Aficionado
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sun Feb 08, 2009 9:25 am | |
| Call Paul at PRJ Performance here in Indianapolis. You could drive over here or I bet with a little coaxing you could get him out to IL for some test and tune. Much better than the genaric PCMs. | |
97rivsc Fanatic
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Sun Feb 08, 2009 10:10 pm | |
| how far would paul be willing to travel? | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Mon Feb 09, 2009 12:38 am | |
| He has several customers in Cali who he has visited several times... Call him to make arrangements... | |
texasfan010 Enthusiast
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Mon Feb 09, 2009 12:44 am | |
| Can you put an intense PCM in a stock car? will it help or hurt. | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Mon Feb 09, 2009 8:28 am | |
| - texasfan010 wrote:
- Can you put an intense PCM in a stock car? will it help or hurt.
Yes you can (as long as it's the right year). It won't hurt much of anything, will alter your shift points and pressures a bit and make it more fun to drive. | |
99prixgt Member
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Mon Feb 09, 2009 10:04 am | |
| imo its one of the most cost effective mods worth doing. | |
mr riviera Member
Name : Pat Location : Syracuse Joined : 2007-10-18 Post Count : 96 Merit : 0
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Tue Feb 10, 2009 4:50 pm | |
| Ive had both ... both serve the purpose the Intense seemed qiucker in my opion but it ran lean. the zzp1.0 puts gobs of fuel in The main thing i like on both was getting rid of that god awfull 40mph w.o.t. lag ... thats worth the cost if thats all it did ... I have raised shift points too ( 6k ) think if i did it again id not get that option | |
Fuzzy Amateur
Age : 52 Location : Hickory, NC Joined : 2007-05-31 Post Count : 37 Merit : 0
| Subject: Intense Racing? PCM no good? Fri Jul 03, 2009 10:11 am | |
| I saw that this looked to be a good company by the post and use of their products on here. Something must have changed since then! I ordered the basic PCM with VATS delete and added the 50 bucks for the core charge. Since it's her daily driver and couldn't do the down time of sending ours in. Well 4 days later we get it(ordered on the 18th of june got it 22nd). Unhooked the battery removed the old replace with new one. Simple drop & swap. Go for test drive. No seat of the pants improvement at all,and to top it off VATS still is engaged and still causing no starts . It does do the 6,000 rpm shifts a WOT other than that I can't tell any differences in shift firmness,performance,etc. We emailed them to let them know that they forgot to delete the vats that night. They replied that they did it that it was a mechanical problem on my end like starter failure,etc. NOT... After explaining to them that the security light is on when it won't start and that when it goes out it cranks fine they promise to send another PCM. Well it's now July 3rd and no PCM. IMO Intense racing just SUCKS | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Jul 03, 2009 10:35 am | |
| What kind of car is this? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Fuzzy Amateur
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Jul 03, 2009 10:42 am | |
| 1997 Riviera *by Buick *Series II Supercharged. | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune Fri Jul 03, 2009 10:47 am | |
| I've had nothing but good experiences with them, even when I've had to return or exchange an item they've been very prompt. I've had them tell me to keep an item i said was bad and they would just ship me another. They don't know me yet trusted my diagnosis. Very similar experiences with ZZP also. returned a bad O2 sensor after 10 weeks, no problem, they shipped me a new one. | |
| Subject: Re: FAQ: ZZP vs. INTENSE Powertrain Control Module (PCM)/Tune | |
