97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Removing PCM (Powertrain Control Module) Wed Nov 05, 2008 11:00 pm | |
| I need to get at the pcm and have absolutely no idea how to do this. Please help! | |
mdhall1 Member
Name : Matt Age : 45 Location : New Braunfels, Texas Joined : 2008-06-15 Post Count : 58 Merit : 1
| Subject: Re: Removing PCM (Powertrain Control Module) Wed Nov 05, 2008 11:10 pm | |
| The PCM is located behind the glove box on the passenger side. Disconnect your battery. Remove the side panel (looks like the fuse panel on driver side) There are six screws holding the glove compartment and kick panel up remove these. wiggle the glove box a little and it will pull out, unplug your trunk release and there it is. My 95 has a red, white and blue plug. If I had to do it again I would order the AC delco from Rock Auto, I purchased a Reman from Autozone I am on my third one and this is finally a good one. Good Luck | |
highwaywarrior Fanatic
| Subject: pcm location Fri Jun 14, 2013 1:51 pm | |
| Where is the pcm location for 98 riviera, just got mine from intense today and want it in... now lol | |
| Subject: Re: Removing PCM (Powertrain Control Module) Fri Jun 14, 2013 1:55 pm | |
| It's behind the glove box. Take off the hush panel underneath the passenger side dash and look up. It's in there. | |
| Subject: Re: Removing PCM (Powertrain Control Module) Fri Jun 14, 2013 1:58 pm | |
| Subject: Re: Removing PCM (Powertrain Control Module) | |
