| BODY CONTROL MODULE | |
+3deekster_caddy TonySmooth89 71stagegs 7 posters |
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: BODY CONTROL MODULE Wed Mar 12, 2008 9:31 pm | |
| I have no interior lights ,lighted visor's overhead lights door lamps but all gauges light I was told its body contol module.Anyone change one of these for interior lights?Thanks steve | |
TonySmooth89 Aficionado
| Subject: Re: BODY CONTROL MODULE Wed Mar 12, 2008 9:45 pm | |
| Did you check fuses? I had something similar to that only the gauges went out too and it turned out to be a fuse. | |
| Subject: Re: BODY CONTROL MODULE Wed Mar 12, 2008 9:52 pm | |
| No not that lucky they are good. | |
| Subject: Re: BODY CONTROL MODULE Wed Mar 12, 2008 10:22 pm | |
| It would help us if you put information about your car in your signature (what year, what have you done to it, etc)
There is also a lighting control module in this car, but it does sound like stuff controlled by BCM...
Interior lights and door lights are generally powered at the same time, double check your fuses. There are fuse boxes all over the car... | |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Re: BODY CONTROL MODULE Tue Dec 09, 2008 5:51 pm | |
| Were is the bcm located in a 96 sc riv? | |
sburch23 Addict
| Subject: Re: BODY CONTROL MODULE Tue Dec 09, 2008 10:40 pm | |
| I have had the same problem after leaving the doors or trunk open so long that it timed out. It also burned out a 10 amp fuse under in one of the blocks under the rear seat. | |
| Subject: Re: BODY CONTROL MODULE Wed Dec 17, 2008 10:10 pm | |
| - sburch23 wrote:
- I have had the same problem after leaving the doors or trunk open so long that it timed out. It also burned out a 10 amp fuse under in one of the blocks under the rear seat.
I found the fuse blocks taped in the harness where was the 10 amp fuse thanks Steve | |
sburch23 Addict
| Subject: Re: BODY CONTROL MODULE Wed Dec 17, 2008 11:40 pm | |
| I found it on the diagram in the owners manual.
My daughter has the car with the manual now and she is gone. I will get back to you when I can give a decription. | |
| Subject: Re: BODY CONTROL MODULE Thu Dec 18, 2008 12:47 am | |
| thanks, all the blocks were good i put a body control module in still no interior lights | |
1995 Riv Enthusiast
| Subject: Re: BODY CONTROL MODULE Thu Dec 18, 2008 1:11 am | |
| A 1995 has A 20 amp fuse in the rear fuse block (under rear seat) marked INTR LP. It also has a relay in the rear relay center ( other black box under rear seat) Marked INTERIOR LAMP RELAY. There is also in the rear fuse block (under rear seat) a 15amp fuse marked I/P 1. The fuses and relays are in the owners manual and inside the lids of the black boxes under the rear seat. | |
| Subject: Re: BODY CONTROL MODULE Thu Dec 18, 2008 11:41 am | |
| I wonder if one or both or your door switches (they are in the door latches not pin switches) failed?
| Subject: Re: BODY CONTROL MODULE Thu Dec 18, 2008 10:22 pm | |
| [quote="71stagegs"]thanks, all the blocks were good i put a body control module in still no interior lights[/quote I found the fuse panel under the seat i had a 10 amp fuse blown I looked in service manual about body control mod i checked reg fuse panel then check the blocks in harness under the seat i don't see anything about rear fuse panel i must have missed it.Thanks to all for your help | |
1995 Riv Enthusiast
| Subject: Re: BODY CONTROL MODULE Fri Dec 19, 2008 12:46 am | |
| Glad it is working what year is your car anyway? | |
| Subject: Re: BODY CONTROL MODULE | |
