| i need help with my radio!!!!!!!!!!! | |
+3Rickw Mr.Riviera texasfan010 7 posters |
texasfan010 Enthusiast
| Subject: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 5:38 pm | |
| ok so i have everything i need to replace my stock radio with a new headunit. When i bought the wiring harness and wired it to the radio i was left with an orange, blue, and two black wires on the wiring harness that werent used. The radio would power up but no sound was coming out of my speakers. Im not very good with radios and stuff and im really stressed. i need your help. Thanks | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 5:53 pm | |
| the only wire i had left over was for power antena b/c i wanted it to stay down. you shouldnt have anything left over. did you match up the colors or did you use the wire diagram that was given with the head unit? from what i recal (it's been a year or 2 since i did mine) the color wires are for speakers.(ie blue wire for left front positive, blue with stripe for left front negative) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 5:56 pm | |
| i just matched up colors, and after that i had an orange wire left, a black wire, a black wire with a white line on it, and a blue wire | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 6:28 pm | |
| https://2img.net/h/i139.photobucket.com/albums/q286/aasearles/layoutCSII.jpg
Don't know if this helps or not. | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 6:39 pm | |
| i would i wire the radio to those speakers then? | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 7:04 pm | |
| I don't understand your question. Did you get a wiring diagram with your harness? | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 7:06 pm | |
| - Rickw wrote:
- I don't understand your question.
Did you get a wiring diagram with your harness? X2 you have to follow the diagram that came with the head unit. the colors dont always match up. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Ryan from Ohio Fanatic
Name : Ryan Location : Toledo, Ohio Joined : 2008-11-16 Post Count : 307 Merit : 7
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 9:23 pm | |
| ^^^ Bingo.
The orange wires are usually for illumination. basically when you turn the lights on the radio brightness dims. I hate that and never use that feature. The remote antenna wire will need to be used to get the antenna up.
You should have an amplifier turn on wire also thats not used. | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 9:43 pm | |
| well my harness didnt come with a diagram, and i got the head unit for free from my brothers girlfriend. | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 9:46 pm | |
| the harness probably wont have a diagram as it's just a middle man to connect the car to the head unit. you should be able to find a diagram online through the mfg website. what unit did you get? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Wed Jun 03, 2009 11:38 pm | |
| Some wiring harness will have what they are labeled right on them.
HU wiring is pretty standard anymore. Just the connector harness is the tricky one sometimes. | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Thu Jun 04, 2009 8:36 am | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Thu Jun 04, 2009 4:54 pm | |
| i got it guys thanks. I got my headunit working good. I have working subs and stuff in as well but do you guys know where there may be a better ground to use, because im using the same ground that the power antenna uses, and thats a long way from my radio. Also wheres the best places to feed wires from the radio and battery to the trunk? Thanks | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Thu Jun 04, 2009 10:34 pm | |
| The factory plug has a ground wire in it. It should be labelled as such on the harness adapter. Or look for solid black... | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Fri Jun 05, 2009 1:55 am | |
| no im talking about the ground wire on the amp | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: i need help with my radio!!!!!!!!!!! Fri Jun 05, 2009 2:19 am | |
| I was wondering, which wire is the power antenna wire? and also, after wiring up my head unit, there was one wire left from the car side of the wiring, and none left from the headunit side........I'm confused and my power antenna doesn't work. | |
T Riley Guru
| Subject: Re: i need help with my radio!!!!!!!!!!! Fri Jun 05, 2009 2:35 am | |
| - 97rivsc wrote:
- I was wondering, which wire is the power antenna wire? and also, after wiring up my head unit, there was one wire left from the car side of the wiring, and none left from the headunit side........I'm confused and my power antenna doesn't work.
yellow | |
97rivsc Fanatic
| Subject: Re: i need help with my radio!!!!!!!!!!! Fri Jun 05, 2009 2:38 am | |
| alright cool thx, o hey did your mom ever let you put your straight pipes back on? | |
T Riley Guru
| Subject: Re: i need help with my radio!!!!!!!!!!! Fri Jun 05, 2009 4:32 am | |
| - 97rivsc wrote:
- alright cool thx, o hey did your mom ever let you put your straight pipes back on?
I could have cut out the muff's whenever... i like my quiet exhaust.. more sleeperish.. | |
| Subject: Re: i need help with my radio!!!!!!!!!!! Fri Jun 05, 2009 8:46 am | |
| - texasfan010 wrote:
- i got it guys thanks. I got my headunit working good. I have working subs and stuff in as well but do you guys know where there may be a better ground to use, because im using the same ground that the power antenna uses, and thats a long way from my radio. Also wheres the best places to feed wires from the radio and battery to the trunk? Thanks
If your amp is in the trunk, ground it directly to the battery ground. It's under the back seat, you need like 2 ft of wire... it's really easy. Same for the power. For the wires from front to back, I ran my RCAs behind the glove box, then down and under the pass. side sill panel to the battery area, then right into the trunk with my pos and neg cables for the amp. | |
| Subject: Re: i need help with my radio!!!!!!!!!!! | |
